Changing center brake light
Old Aug 24, 2010 | 09:37 PM
GGRJR's Avatar
Has anyone changed the center brake light on a first gen G35 sedan, with out wing. Just found out today mine is out, dealer wants 350.00 to replace. I can get teh part online for like 150.00. Looks like it requires removing rear seat and package shelf. How difficult is it? Am I better off just letting the dealer do it?
Old Aug 24, 2010 | 10:02 PM
Mustang5L5's Avatar
Common issue
It can be done, but gotta go in through the back seat to get one of the bolts. Just set aside a Saturday where you have nothing to do, some beer and some good assorted tools and you'll get it done
Old Aug 25, 2010 | 10:20 AM
OKStateG35's Avatar
The best way to do it is to remove the seats and rear shelf so you can gain full access. I haven't tested it out, but if you have reclining seats it may be possible to remove the rear shelf without removing the seats first.
You can also access it through the trunk, but you will need to drill a hole to be able to access the passenger side screw.
I did this last month so let me know if you have any questions.
Old Aug 25, 2010 | 10:39 AM
Wannabe6MT's Avatar
-MN G Crew-
I did it by going through my trunk and reaching up. Drivers side screw is easy, passenger side not so much. I didn't i=even end up putting it in, just tightened down the drivers side well. Seems to be holding in place!
Old Aug 25, 2010 | 10:58 AM
OKStateG35's Avatar
^ I don't know how you removed that passenger side screw without drilling a hole. I couldn't even see it, much less get a screwdriver up there.
Old Aug 25, 2010 | 11:58 AM
Wannabe6MT's Avatar
-MN G Crew-
I had just enough wiggle room to get it out.
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
mike730
Jan 12, 2018 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
Lsantana757
Jul 20, 2015 09:08 AM
