Headlight help for daughter, please
Old Aug 27, 2010 | 06:32 PM
RicoG35x's Avatar
or do it yourself for the $$ of a pair of 6000K PIAA's.. and save about $150!!
Old Sep 3, 2010 | 06:22 PM
eb20004x4's Avatar
Update (and continued thanks!)
My son checked the wiring and saw nothing out of line. Took it to the Nissan dealership and now they are diagnosing that both ballasts are bad. I have a hard time understanding that BOTH went bad at the same time (also having a hard time stomaching a $1,000 repair). Anyone have any thoughts? I'm not necessarily doubting they are bad but I don't want something upstream causing the failure. Plus, they have not tested them but are just going by the diagnostic flowchart.
Old Sep 3, 2010 | 10:47 PM
socalwdup's Avatar
You can get them used for $200.
Hit up mrwong@statik... And it's easy to install it yourself.
So with four bulbs+ballasts= $240.
Plus install is easy
Good luck!
Old Sep 3, 2010 | 10:49 PM
Wannabe6MT's Avatar
-MN G Crew-
Buy aftermarket if you can. DDMtuning sells kits for like $30. Thats what i use in my fogs, i'd probably do the same in my headlights if i had to.
Old Sep 4, 2010 | 04:25 AM
socalwdup's Avatar
bulbs of hid?
Old Sep 4, 2010 | 09:07 PM
NjMatteSedan's Avatar
Originally Posted by socalwdup
I wish I had a dad like you...
he´d probably still whoop your a$$ for drifting accidents
Old Sep 4, 2010 | 11:38 PM
brewcrew1982's Avatar
Originally Posted by ilovez33
Im having the same issue with mine. When i hit bumps my passenger side headlight will flicker off and the only way it'll come back on is if i turn them off and on back. When the lights out and i tap the headlight housing or hit it, they wont turn on so I dont think its a the ground wire but what do you guys think.
This is the EXACT same problem i am having right now. My passenger side HID headlamp will go out sometimes if i hit a bump or hit the headlight housing with my hand. If i turn the headlights off and then back on, the passenger one comes back on every time.
I don't necessarily think its a bad connection because the light always turns back on by just turning them off and on. Once its out, I dont need to tap the light or wiggle the wiring or anything like that, just switch the lights off and back on, but i dont really know too much about this type of stuff.
Anyone know what is wrong or have any suggestions? I'm gonna try to pull the bulb out through the wheel well and re-connect everything on tuesday probably...
ilovez33, if you read this, what did you do to fix this problem??
Old Sep 5, 2010 | 01:25 AM
socalwdup's Avatar
Grow up, mature some, and stay on topic.
My headlights are like that too, but now, it's completely out.
Old Sep 6, 2010 | 03:35 PM
bump...
happy labor day!
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
