Coolant!!!
Old Aug 31, 2010 | 11:57 PM
jayflyxx's Avatar
Coolant!!!
so my car which is an 05 is at 115k and ever since I can remember is always low on coolant in the bottle. check the radiator and hoses for leaks and everything checks out ok! even had it check at the mechanic.. whats up with that anybody else notice that.. like every other month i fill the bottle to the max..
Old Sep 2, 2010 | 12:37 AM
bythabay's Avatar
Did your mechanic perform a cooling system pressure test? I would start with that first.
Old Sep 2, 2010 | 01:02 PM
al_macaroni's Avatar
I have 123,456 miles on my '05. I probably add some coolant every 6 months. I don't need to add it on a monthly basis. I did change the radiator cap a year ago at 100k mi. I think radiator cap replacement is listed in the factory maintenance schedule.
You might want to give that a try as it is a simple and inexpensive item to replace.
Old Sep 4, 2010 | 08:37 AM
jayflyxx's Avatar
i'll try replacing the cap. just seems a little weird to be using that much and not seeing it on the ground or underneath! the coolant system was tested too btw.
Old Sep 5, 2010 | 10:41 PM
asma123's Avatar
Check your oil to see if you have a white foam or the oil cap if there's a white layer of some sort of substance. If you do I would get rid of this car ASAP since it could be your head gasket.
MrIP35
Oct 25, 2015 11:13 PM
BradMD_96
Oct 6, 2015 09:31 AM
Usman Ali
Sep 22, 2015 06:59 AM
DRG35R
Sep 16, 2015 05:33 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
