need toe bolt?
Old Sep 4, 2010 | 01:30 PM
toymachine2009's Avatar
need toe bolt?
I am lowered on 350z s-tech.. Bought a camber kit off a vendor on here and said I would most likely not need a toe bolt kit with my camber kit! So I ordered without one. I get to the shop today to get camber kit installed and they say I NEED a toe bolt kit. Just wanna make sure if I really do or not.
As far as I know my camber was out of whack thats it! Never my toe was bad or anything. Nor does it look like it.
Old Sep 4, 2010 | 01:38 PM
SN00P's Avatar
CLUB MODERATOR
i had 350z s techs on my car and i didnt have a rear camber kit or rear toe bolts .. my camber was off but i got my toe within the spec ...... but you might as well just get some toe bolts and throw on your car and never have to worry about it again .. thats what i did with my new set up
Old Sep 4, 2010 | 01:45 PM
Well at 67 dollars an hour labor they told me 2 hours JUST to install the toe bolts if I dont NEED it I rather not pay for it! I didnt have a rear camber kit either and a year and half the inside of my tires were no good anymore.
Old Sep 4, 2010 | 02:01 PM
SN00P's Avatar
CLUB MODERATOR
i paid 90 bucks for my rear camber kit installed and toe bolts :-) id rather pay that then me having to do it ... toe bolts are nowhere near 2 hrs LOL ill the do is cut or dremel a little bit and stick the new bolts thru and start turning .. hell thats a 30 min job
Old Sep 4, 2010 | 02:03 PM
Well **** then I gotta find a new Shop to go to.... Dont have much of a choice. Literally I been to 3 different auto shops and EVERYONE has given me different opinions and what not! I swear I cant find a good shop in Vegas thats honest and is not just looking for money!
Old Sep 4, 2010 | 02:36 PM
Just got off the phone with the shop so here is what it comes out to! They say 135 to install camber arms and 90 dollars to roll fenders. and when I get toe bolts 135 to install those because of all the honing they have to do!
I asked to I really need the toe bolts. What he said was yes because when you get an alignment and they get your camber all set it will then misalign your toe. Is this true?
Old Sep 4, 2010 | 02:52 PM
socialconflicts's Avatar
those prices are hardcore, the rear camber kit is super easy to install... its like 2 bolts including the oem toe bolt... and fenders should be about 50-60 for both sides.
Old Sep 4, 2010 | 02:57 PM
they wanted 90 for both rear fenders.. The other shop in town wanted 20 per fender but couldnt guarantee that my paint wouldnt chip.. You get what you pay for...
Still havent really gotten an answer.. Do I NEED toe bolts or am I fine without them?
Old Sep 4, 2010 | 02:58 PM
SN00P's Avatar
CLUB MODERATOR
90 bucks for both fenders rolled sounds fair ... if you have like 2 hours of free time and a jack you can do the whole rear camber yourself . its super easy :-) ...
like i said before i got my alignment done a months ago with the 350z s techs got a good alignment . toe was in the green and camber was in the red and i never had a problem
Old Sep 4, 2010 | 02:59 PM
i would just sell the camber kit, and use that to get our fenders rolled if u need it.
Old Sep 4, 2010 | 03:00 PM
well before I got this camber kit I had same thing as you my Camber was Bad but my toe was fine. Inside of my tire got worn out pretty quick so I decided to get a kit and didnt know I need toe bolts because I thought since JUST my Camber was off I wouldnt need them. Now there saying I do!
Old Sep 4, 2010 | 03:01 PM
SN00P's Avatar
CLUB MODERATOR
TOE kills tires faster then camber .... i would just throw them on now "toe bolts " and never worry about wearing anymore buddy
135 for install one time only or 600 bucks for new tires all the time ...
Then My tires would wear down on the insides really bad..
Old Sep 4, 2010 | 03:06 PM
yea im sure thats what ill probably end up doing. Looks like I gotta order some toe bolts and get those installed!
Ill see what happens after alignment if needed and how bad it is out of spec.
Old Sep 5, 2010 | 12:33 PM
obender66's Avatar
It is possible that you will not need toe bolts after installation of camber arms. After camber is brought in line, toe will change as well.
Less negative camber=more toe out.
I had 2.19 degrees toe in(waaay out). After installation of camber arms it became 0.19 degrees in. I am not sure what the stock specs are, but this is sizeable improvement in the right direction. Now, the problem is that my toe bolt is seized inside the bushing and toe is not adjustable until I replace the bushing. With otherwise good stock toe bolts it is possible to bring toe within spec.
When installing after market toe bolts(I got them too, but only one side was installed) frame must be slotted to take advantage of increased adjustability. Lots of shops are f... clueless about that and just install the bolts.
