03' G35 HID problem
Old Sep 19, 2010 | 06:52 PM
DRE073's Avatar
03' G35 HID problem
Recently my driver side headlamp started to flicker until it goes off whenever I start my engine. Once I turn my lights off and turn them back on it temporarily fixes the problem, until i do another engine start. After this started happening I realized that my drivers side headlight is now a bluer tone than the passenger side. The headlights are factory. I've never changed them. Any ideas as to what could be happening?
Thanks
Old Sep 19, 2010 | 07:28 PM
nazc0's Avatar
2006 Vortech supercharged Sedan
sounds like the balast to me but im not an expert someone will chime in soon
Old Sep 19, 2010 | 07:32 PM
G35Papa's Avatar
Same happened to me when my bulb was going bad. Eventually, it just died out completely.
Old Sep 19, 2010 | 11:49 PM
Mustang5L5's Avatar
Easiest thing to do is swap bulbs and see of the prob goes to the other side. If it does....get new bulbs
Old Sep 19, 2010 | 11:52 PM
kyemaul's Avatar
u can check the balast by puttin a different bulb if it does the same thing then u need to change the balast if the balast is good u will kno its just the bulb n u would have fixed da prob !!!! but sounds like a bulb to me!!
Old Sep 20, 2010 | 10:25 AM
azt108's Avatar
Definitely a ballast issue. Replace your ballast. Aftermarket ballasts are very cheap, look into it.
Old Sep 20, 2010 | 11:36 AM
WILLIE BEANS's Avatar
same happened to me .i had to replace my ballast ..
got mine off ebay ..
Old Sep 20, 2010 | 12:24 PM
thn116's Avatar
I had similar problem. It ended up being my bulb.
Old Sep 20, 2010 | 02:36 PM
5150DS's Avatar
Bulbs/ballasts cheap here + available lifetime warranty:
http://www.ddmtuning.com/products/101/
Jusseth
Sep 13, 2020 12:25 PM
bTanz
Oct 15, 2015 02:31 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
attarday
Jul 15, 2015 04:03 PM
