Shock/Suspension Recommendation ('04 Sedan)
Old Sep 21, 2010 | 12:50 PM
Swivel's Avatar
Moderator
05, came off red35's TT/6MT coupe so they are 427s. Didn't make me any faster, though, LOL!
Old Sep 21, 2010 | 01:07 PM
NFSP G35's Avatar
? = 2B || !2B
^I don't understand why you would have a slight rake.
Mine came off a 06 sport coupe, and they are 427's that are the exact same length as z springs.
Old Sep 21, 2010 | 01:11 PM
Swivel's Avatar
Moderator
Yes, they are. I should clarify; my wheel gaps are pretty even, and my car does not sit as level as I've seen those with full Z setups, the rear is a tad higher than the front. Full Z's that I've seen seem to have a bit less gap in the rear, hence they sit more level and I don't know why since the springs appear EXACTLY the same just by eyeballing. Sometimes it varies from car to car, too.
Old Sep 21, 2010 | 01:42 PM
grocerylist's Avatar
What's a fair price for an auto shop to install springs all around, struts and shocks? I had some maintenance done last weekend (100k service) and was charged $80/hour! I want to make sure I'm not getting hosed on my suspension labor quote.
Old Sep 21, 2010 | 03:51 PM
Originally Posted by SwivelHips
My rears are coupe sports. OP, lots of good reading here:
https://g35driver.com/forums/brakes-...w-updates.html
What do the numbers for the springs mean?
350Z’s 2003/2004 (unrevised)
Front:314 Rear:342
G35 sedan's with non sport
Front: 283 Rear: 308
Old Sep 21, 2010 | 05:40 PM
Blue Dream's Avatar
I drove ttrank's car solo
Oh what a difference a day makes on Driver.
Originally Posted by grocerylist
I don't plan on lowering the car any.
If I go your recommended route with Z fronts and coupe rears... what shocks do I go with? The G35 struts/shocks all around or Z struts up front and coupe shocks in back?
Just know you are headed down a very dangerous and slippery slope because once you get mod fever it never really goes away. A lot of us have started off with the "I just want a little drop" mentality and you wake up one morning down the road and you car looks like one of these and you're broke as a joke:
G35Papa
FlyingLumpia
SDGenuis
OCG35
SouthBayGSedan
4Dr.Madness.
Ttrank
G Sedan
CandlestickPark
Old Sep 21, 2010 | 05:46 PM
Swivel's Avatar
Moderator
Front:314 Rear:342
Those are the spring rates in lb/in, that is, how many pounds it takes to compress the spring one inch. Higher number = stiffer springs, obviously.
LOL @ Blue Dream trying to give the n00bs visual mod-itis
Old Sep 21, 2010 | 05:58 PM
Blue Dream's Avatar
Just a friendly warning.
Old Sep 21, 2010 | 10:36 PM
Footballmania32's Avatar
As I was scrolling through those pictures I almost felt like I was meeting an all-star team or something haha.
Old Sep 21, 2010 | 10:40 PM
NFSP G35's Avatar
? = 2B || !2B
Blain should be on that list too.
Old Sep 22, 2010 | 12:47 AM
heph's Avatar
Thanks a lot Blue Dream. I find myself pondering trunk lips, among other things, for some reason.
Old Sep 22, 2010 | 03:03 AM
4D05G35's Avatar
I'm sure they were rubbing... but only when I have a heavy load of passengers. No spacers either.
The front height imo is too tall. I would like to lower the front for sure for looks and a stiffer ride. Would the car ride odd with lowering the front but keeping the rear stock? I plan to do the struts/shocks with the Tokico HPs.
I would recomend either front/rear revised z springs (04.5+) if you want about a 1" drop, or z front springs and unrevised coupe (pre revised rear springs). The z fronts will lower/stiffen up the front and the unrevised G rears will lower/stiffen about .5-.75" .....
once revised, the higher rate rear springs for the z and coupe are the same so you may as well just get a set of oem z springs. If you want some springs, I have some oem available...I think they are coupe fronts and rear. I would have to double check.
I am running G/Z combo with Z tokico shocks with no problem at all.
Old Sep 22, 2010 | 05:21 AM
Blue Dream's Avatar
We've all been there. A lot of those cars have changed since those pics were taken last fall.
Old Sep 22, 2010 | 09:44 AM
Thanks for all the information from everyone. I'm now looking for springs in the marketplace here.
Old Sep 22, 2010 | 09:53 AM
  #30
Swivel's Avatar
Moderator
^^ Check my350z.com also. Don't ignore your local Craigslist/Kijiji, either.
