Shock/Suspension Recommendation ('04 Sedan)
Old Sep 22, 2010 | 05:39 PM
  #31
NFSP G35's Avatar
? = 2B || !2B
^eBay too.
Old Sep 22, 2010 | 06:01 PM
  #32
Swivel's Avatar
Moderator
Originally Posted by 4D05G35
I would recomend either front/rear revised z springs (04.5+) if you want about a 1" drop, or z front springs and unrevised coupe (pre revised rear springs). The z fronts will lower/stiffen up the front and the unrevised G rears will lower/stiffen about .5-.75" .....
once revised, the higher rate rear springs for the z and coupe are the same so you may as well just get a set of oem z springs. If you want some springs, I have some oem available...I think they are coupe fronts and rear. I would have to double check.
I am running G/Z combo with Z tokico shocks with no problem at all.
Technically, G springs were never revised, but in 05/06 you could get sport springs (19" wheel equipped cars) but you could still get non-sport springs. But the sport springs are the same rate as Z revised and physically appear to be exactly the same.
Not being completely **** here, just trying to save some confusion. Lord knows I cause enough of it.
Old Sep 22, 2010 | 06:03 PM
  #33
NFSP G35's Avatar
? = 2B || !2B
Does anyone know what springs the early sport pkg coupes had?
Old Sep 22, 2010 | 09:58 PM
  #34
4D05G35's Avatar
You just caused a bit more ...so "technically" speaking the revised 350Z springs in 04.5 are the same springs as the 05/06 G coupe sport springs of 05/06!...I never meant to imply that they revised the G coupe spings...Well agreed upon....
Old Sep 23, 2010 | 12:57 PM
  #35
grocerylist's Avatar
Yeah, if you want a slight rake to your stance, go with the G/Z combo:
Easiest route is to go with the struts that come with the springs, especially on the front, since they usually come 'assembled', like so:
I'm a little confused on the front struts. If I'm getting new struts they won't be coming with springs. I'm plan to purchase the revised coupe/Z springs. When ordering the struts I see that there are different struts for the G35 and Z. Which struts should I use? Or what differences in ride height would I experience with each?
Thanks again!
Old Sep 23, 2010 | 02:21 PM
  #36
NFSP G35's Avatar
? = 2B || !2B
Either would work. Height is deccided by the springs, not struts.
But since you're going with z springs in front, might as well go with z struts too.
Old Sep 23, 2010 | 03:07 PM
  #37
Thanks. I realized that the springs determine the height but I didn't want to have a strut that was too short and end up having the spring slightly compressed.
Old Sep 23, 2010 | 10:31 PM
  #38
thescreensavers's Avatar
Mr.202?
Originally Posted by NFSP G35
It shouldn't be too hard to eliminate the rubbing. Once you've got that squared away, go lower. The one inch drop you get from revised z suspension is really nice. Makes the car look better, it's cheap, and firms up the ride a bit without making it uncomfortable.
Also, if you're running Z suspension, you can just have the shop use alignment specs for a 350Z, and it should go into spec.
Lol yea. When I took my car for an alignment the guy in the shop though I did some cheap drop like cutting springs or something. Since. Left side of the car was- 1.1 and the right was -0.7. But I had an empty tank of gas so I am pretty sure that messed it up.
I never rub with the 18s
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
smartin0924
Aug 13, 2015 07:29 PM
multimut
Canada
Jul 26, 2015 08:43 PM
