2005 G35X wheels. Show me your X with Wheels.
Old Sep 23, 2010 | 09:54 AM
smahara's Avatar
Hey Folks,
recently purchased a 2005 G35x Sedan, it came with the 17" wheels. I have been looking on the site and i see lots of non X sedans with aftermarket wheels.
Post up your X pics with rims, I wanna have an idea what it looks like and how many of you are running X with staggered wheels.
Thanks
Old Sep 23, 2010 | 11:29 AM
heph's Avatar
It's even stickied for your viewing pleasure:
https://g35driver.com/forums/g35-sed...uspension.html
Old Sep 23, 2010 | 11:51 AM
ccc123pm's Avatar
X
staggered setup is not recommended... two members with awd and rims that come to mind are FlyingLumpia and mccaron
Old Sep 23, 2010 | 03:11 PM
Bestswat's Avatar
There are members running staggered on AWD including me, just need to buy the right tire sizes.
Old Sep 23, 2010 | 03:43 PM
seddon's Avatar
Alot of AWD sedan run staggered wheels. I ran them for 4 years no problem. Like I told the dealer when they tried to bs me " the car know rolling diameter not rim width". The right tires are your friend.
Old Sep 23, 2010 | 03:46 PM
smahara's Avatar
well show me the rims
Old Sep 23, 2010 | 05:35 PM
Blue Dream's Avatar
I drove ttrank's car solo
I guess you missed this post that was just above your last one and just before your first one.
Old Sep 23, 2010 | 05:38 PM
CandlestickPark's Avatar
ill Sedan
FlyingLumpia, I think his wheel/tire setup is:
19 x 9 - 225/40
19 x 10 - 255/35
Old Sep 23, 2010 | 05:44 PM
Matzo Ball's Avatar
the wheels are not the issue, its the OD of your tires. The X Altessa AWD system allow for a touch of flex within the diamaters of your tires (approx .1-.3"). The important thing is the run the slighly larger OD on the front so the rear does not sense any slipping.
I run 225/40/19 front and 255/35/19 rear. I have a .1 difference with the front being the larger OD. No issue at all.
Lots of threads on this. Do a search and you should see some good info/pics.
Old Sep 23, 2010 | 05:47 PM
ill Sedan
^Exactly what he said.
Old Sep 23, 2010 | 08:12 PM
lowerd4lyfe's Avatar
Im looking for a set of wheels as well...Will most Rim shops know this about AWD cars? Did you have to run any spacers to have that setup? Sounds like thats the most common setup ur running....Are those 19 x 8 and 19 x 8.5s?
Old Sep 23, 2010 | 08:26 PM
ill Sedan
What kind of wheels are you looking into? Just tell them you want to run 225/40/19 and 255/35/19 tires. A 8.5/9.5 or 9/10 (will be a tiny bit stretched) staggered setup would look good with those tire sizes.
Old Sep 23, 2010 | 08:37 PM
To be honest Marcus, I want a set of Bronze in color not sure what kind yet, Not to many spokes, Decent rear lip (maybe $ bill width) but nothin to wide that I gotta Roll any metal...I dont know to much about the spacers. But, I want the rear to be close to flush without rubbin on the qrtr. Size wize maybe 18's or 19s..I want to lower it alil, but not sure if I should lower first or go with wheels.. Any ideas would be much appreciated.
Old Sep 23, 2010 | 09:59 PM
Matzo Ball's Avatar
Most tire/wheel shops will advise against running staggered on AWD. I specifically asked the Infiniti service advisors about it and they confirmed the information I previously posted.
I am running 19x8.5 all around but using a staggered tire set up b/c they were brand new when I switched (was 19x8 and 19x8.5). Personally i like 8.5/9.5 for wheels.
I have 5mm spacers front and 10mm spacers rear. Spacers have no effect on an AWD system.
Old Sep 24, 2010 | 01:04 AM
G35xChicago's Avatar
There are a lot worse things we do to throw off the original geometry of our suspensions than the staggered/awd wheel issue. Go for it and keep the rolling OD as close as you can like everyone else said.
