Need Advice Help for my Flush
Old Oct 12, 2010 | 06:29 PM
b-dRizZy's Avatar
peeps so i bought My Volks GT7 19" but only got the Front ones they 9.5 but now i need the back ones and i was gonna go with 10.5 but is gonna be 2 wide whats a good size to get i want to be a little flush but not extreme my sedan is a "daily Driver" so cant have too crazy on it ... need help peeps on getting these sizes plz help thanks this is a previes off my car on the Riverside Meeting the back GT are frm Speedream he was koo enouf to let me baroow them for the meet..
if you can send me piks of examples that will be great ..so i can see
Old Oct 12, 2010 | 06:35 PM
CandlestickPark's Avatar
ill Sedan
What are the offsets of the 9.5s you are running now? Tire size? Plans to go lower or staying at your current ride height.
Old Oct 12, 2010 | 06:58 PM
b-dRizZy's Avatar
tire size on my front ones is 245/35-19 but i will switch too 215/35/19 soon
idk the size and dimensions of the volks i got right now just that they are 9.5
well i have coils so ill probly have it a little bit higher then whats on the pik ?
Old Oct 12, 2010 | 07:03 PM
Jeff92se's Avatar
Red Card Crew
215-35-19 is way too small.
Old Oct 12, 2010 | 07:18 PM
SN00P's Avatar
CLUB MODERATOR
if you have a 215/35 on the front you better slam the sh*T out of your car or it will look funny !!! and since you want to DD your car and not go crazy 215 is to small for you.. IMO just keep what you have and add some spacers and make then 245s flush :-)
Old Oct 12, 2010 | 07:21 PM
b-dRizZy's Avatar
yeah but the wheels are no daily driver just the car lol but like i need suggestions on the back rims ?
Old Oct 12, 2010 | 07:23 PM
b-dRizZy's Avatar
well your right and probly will keep my tires what i have ..
and yeah i have 15mm spacers on it i was prety almost flush the day off the riverside meet. i just dint slam it cause i dint wanna hit the whole way on the frw but for the long beach meet i will be flush
SN00P's Avatar
CLUB MODERATOR
do you at least have fenders rolled flat ..... what's the most modifications you want to do with the back fenders .... hellaflush = fender work
Old Oct 12, 2010 | 07:27 PM
b-dRizZy's Avatar
weelll hoping by the long beach meet i will have my fenders roll
i did a micky mouse fender roll the day before the riverside meet cause it was just hitting at every little bump everywhere
Old Oct 12, 2010 | 07:29 PM
SN00P's Avatar
CLUB MODERATOR
how much camber do you want to run is your big question .... do you have a rear camber kit ??
Old Oct 12, 2010 | 08:47 PM
b-dRizZy's Avatar
See that another question WTF is. A camber lol
And if it's aftermarket piece then most likely no
Old Oct 12, 2010 | 09:03 PM
SN00P's Avatar
CLUB MODERATOR
do you know want camber,toe,caster is ???? its when you drop your car and your wheels go sideways .... you will burn thru tires super fast like levon does @-7º lolol some of the other guys in here a few run around -3º to around -3.5º of camber ..... camber arms fix the problem so you will not eat thru tires every 5000 miles .... your better do some reading on that stuff before you want to be hella flush :-)
Old Oct 12, 2010 | 10:42 PM
Equipped4dr's Avatar
Im not sure if you will decide to get a camber kit in the future. If you just want to save some money and roll without one you should pick up some 10.5 with a high +30's offset low +40's offset. Fenders rolled flat you should be able to run a 265-35 tire size. The gt7's you had in the rear there are +44 offset.
Old Oct 12, 2010 | 10:48 PM
b-dRizZy's Avatar
Lol allright I got it now .. Well then that don't reply matter to me I only put on rims for run is show time but of anything I'm down for a -3.5 camber
Old Oct 12, 2010 | 10:50 PM
b-dRizZy's Avatar
Yo speedream ima roll to your pad Thursday pick up my pop charger lol after I get off skool
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
