P1121, VDC off, SES, Car won't start
Old Oct 24, 2010 | 01:43 PM
vkomatre's Avatar
Please help, I have a 2003 G35 sedan. Got a service engine soon light, took it to autozone who gave a error code P1121. Sometime I get the VDC off and slip lights on and now the car won't start. Anybody who had similar issues? what would be the repair costs or is there something I can do to fix it. Pls help.
Old Oct 24, 2010 | 08:02 PM
t3_123's Avatar
ok this is what i found. P1121 Electronic Throttle Control Actuator.
This site has all codes for our cars if you have more then one.
http://www.6mt.net/forum/g35-sedan-2...how-clear.html
This is how you fix the problem.
http://my350z.com/forum/maintenance-...e-problem.html
Old Oct 24, 2010 | 08:03 PM
t3_123's Avatar
looks like the same problems. good luck let us no what happens.
Old Oct 24, 2010 | 08:43 PM
GOAT35's Avatar
same thing but my car would turn off in 5 mins after a good start.....bad oxy sensor behind engine...... 45 bucks on master card. 1 hour of mechanic's service at stealership 82 dollars on master card! Almost getting rear ended because ur car just cut off-Priceless.....but im positive GIECO could put a price on that!!
good luck mahn!
Old Oct 24, 2010 | 09:05 PM
silver knight's Avatar
i had same code after cleaning my throttle body. reset and cleaned again and has never come back on.
Old Oct 25, 2010 | 01:41 PM
vkomatre's Avatar
taking it to the shop for a full diagnostic, if it confirms throttle body probably clean it up and see how it goes. If it comes back again then will order a reman online and hope it fixes. Any ideas which is better a A1cordova or Hitachi?. Will keep you posted. Thanks for the replies guys.
Old Nov 2, 2010 | 12:14 AM
vkomatre's Avatar
Finally fixed. Thanks to the throttle body cleaning video and ECU reset directions. Followed directions in the video, (before starting the whole process disconnected battery) took throttle body out, cleaned it, replaced the gasket and fixed everything back. Then did the basic ECU which fixed the SES light, initially. But the light came back the next day. Did the ECU reset again and no issues as of now, 2 days and counting. Thanks everybody.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Aug 17, 2015 01:24 AM
