Full size spare tire in your trunk?
Old 10-29-2010, 02:08 AM
DrewLe's Avatar
Full sized 17' spare here with the premium package C.
Good thing cause I hate messing with donuts....other than the ones you eat lol.
  #32
Old 10-29-2010, 02:10 AM
thescreensavers's Avatar
Mr.202?
Originally Posted by Mustang5L5
Like I said before...
For 05/06
Prem B package - space saver spare
Prem C package - full size spare.
ok lol just making sure. Mine is B so yep I get
  #33
Old 05-14-2012, 02:17 PM
mrwgottaG35's Avatar
ive got the same exact tire and rim in my spare compartment that i have on the car. came like this when i got it, not sure if this is what yall mean by full size spare but it fits perfectly no loss of space and if i get one more scratch on my driver front rim, i'm switching it out lol
  #34
Old 05-16-2012, 10:12 PM
312G's Avatar
What is a premium package? I do not even have automatic door locks or power tilt/telescope steering wheel or memory seats. But I have full-size matching spare 17' whheel. It does not sit flush in the trunk. As a result there is a hump under the trunk carpet.
  #35
Old 05-17-2012, 09:52 PM
4mermarine's Avatar
Had one. Got rid of it for a donut. Save a few precious pounds.
  #36
Old 05-17-2012, 11:03 PM
mysoda's Avatar
2003 sports sedan. with couple couple 18inch rims. do you guys know if a coupe 18 fit perfectly in my spare tire area?
or can i use my donut rim with my coupe 18 rims if i have flat tire on one rim?
  #37
Old 05-20-2012, 05:59 AM
mysoda's Avatar
come one. no one has ever try to put coupe 18 in the their?
  #38
Old 05-20-2012, 06:53 PM
D.Reaper's Avatar
i have a G37s coupe spare in mine
  #39
Old 05-25-2012, 04:04 AM
mysoda's Avatar
is that 18 in?
  #40
Old 11-07-2014, 01:53 PM
sumptimwong's Avatar
I just purchased a used 2006 6MT sedan, and I found a full size 17" 7-spoke wheel in the trunk. It doesn't look like it belonged there however, as it sticks up above the plane of the trunk floor and my trunk space looks like some rolling foothills.
Can you all tell me what the spare/trunk is supposed to look like with a compact in there? I think I want to get rid of the full and put a compact in so my trunk is flat again. I also don't feel the need to carry around that extra weight all the time. Is there also some kind of rigid board, or a foam insert to keep the floor flat? Right now the spare tire well is just a cavity with a wheel and the tools rattling around. Seems like I'm missing something..
  #41
Old 11-07-2014, 07:13 PM
05_SkylineSedan's Avatar
Check this drawing:
http://www.infinitipartsusa.com/2006...ts-s/11957.htm
Parts 20, 21 & 22 are Styrofoam spacers which raise the floor level of your trunk to match the full-size spare. Part #17 is the pressed-wood piece which sits between those 3 pieces to cover the hole where the tire is and make the floor flat.
We had full spares in our '05 and '06 Gs. I don't know if you still need those spacers if you have a donut.
sumptimwong (11-11-2014)
  #42
Old 11-08-2014, 04:31 PM
skippyG's Avatar
Mine has a full size alloy rim with the original RS-A on it....
  #43
Old 11-08-2014, 07:57 PM
TurTLe*'s Avatar
Mines has the full size tire.
MINT condition rim and new tire. Being that its 10 years old now, i wonder if its worth replacing... I've used the spare tire once, maybe put 9 miles on it.
  #44
Old 11-10-2014, 11:45 AM
Mustang5L5's Avatar
Originally Posted by 05_SkylineSedan
Check this drawing:
I don't think 20, 21 and 22 are used with the space saver. But then again i think I recall a pic where the tools are on the board over the space saver.
Either way, i want to say it's much different than the full size spare.
  #45
Old 11-10-2014, 11:51 AM
Mustang5L5's Avatar
Eh, if you plan on just using it temporary i wouldn't worry about it. If you think you might get a flat and need to drive 200 miles on it, then i might for security. Although with the tire being out of UV light, as long as i didn't see dry cracks on it i would trust it.
Does your full size spare have a TPMS sensor in it??
Mine does, and a long time ago i dented a rim and swapped my full size spare out and put the dented one in as my spare. The tire is worn, so i prob should replace it in case i get a flat in the winter. But my full size spare DID have a TPMS sensor, but when i swapped it, i had to reregister the sensors (did it myself using the method talked about on the forums by varying tire pressures)
marsman328
Northern California
08-11-2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
08-10-2015 07:04 PM
wuppiedog
08-07-2015 11:16 AM
Cam_Cooper3
08-04-2015 01:53 PM
Quick Reply: Full size spare tire in your trunk?
