Group Effort to push for 3rd brake-light recall. READ IF YOURS IS OUT!
There is an existing thread on this subject here but because the subject is a bit vague, I thought it best to create a new thread that will hopefully get more attention.
It seems that a common problem with the spoilerless G35 Sedan is that the third brake light (the one in the back glass) either does not work, or works intermittently. Apparently, Infiniti is either unaware of this problem, or (more likely) trying to brush it under the rug. Several members have reported that informing Infiniti of the issue has done little good, so a better option would be to report the problem to the National Highway Traffic Safety Administration (NHTSA) and report the problem to them. If enough people report the same problem, NHTSA will launch an inquiry which will hopefully result in greater attention from Nissan/Infiniti in this matter, and possibly a recall. Clearly, NHTSA will be very interested in this information because of the obvious safety implications of a non working brake light. NHTSA can be reached by phone at 888-327-4236 Also a complaint form can be filled out here: https://www-odi.nhtsa.dot.gov/ivoq/ The form is easy to fill out and only takes about 5 mins. Members that have already sent in a report via the online form: 1) thescreensavers 2) Enochian 3) Wannabe6MT 4) Mustang5L5 5) NFSP G35 6) OKStateG35 7) fobizzle 8) heph 9) Junkyardspecial 10) nazc0 11) incubus3612 12) D10 04G 13) G35Papa 14) Lowerd4lyfe 15) G35Luv 16) VstyLe09 17) ntoxtiger 18) G35SedanGrn 19) XDR-V35 20) 19kdrill 21) 054DRG35 22) DG Steelo 23) petro2342 24) afr0puff ('03 Coupe) 25) NYYBaseball423 26) khull26 27) vq35dedriver 28) kday (G Coupe) 29) G35 Owner ('04 Sedan) 30) jonesmeister11 31) G_VQ3577 32) Antoniog35 33) Drift King 34) fjterry 35) O4G35DPM 36) DrewskiLe 37) dcsaggiesarge 38) evosmudge 39) vladkalika[/quote] 40) g35kid00 41) Wrathernaut 42) xRayZx 43) ktownlobo 44) 40fortpa 45) G35_FTMFW 46) EnerOnE 47) NAT@FFTec 48) TRN 49) FlyingLumpia 50) Indyjrt 51) pyropro |
If i'm not mistaken wouldn't this apply for coupe's also?
1) thescreensavers
2) Enochian 3) Wannabe6MT 4) Mustang5L5 5) NFSP G35 6) OKStateG35 7) fobizzle 8) heph 9) Junkyardspecial 10) nazc0 11) incubus3612 12) D10 04G 13) G35Papa 14) Lowerd4lyfe 15) G35Luv 16) VstyLe09 17) ntoxtiger 18)G35SedanGrn |
Originally Posted by DG35coupe
(Post 5464778)
1) thescreensavers
2) Enochian 3) Wannabe6MT 4) Mustang5L5 5) NFSP G35 6) OKStateG35 7) fobizzle 8) heph 9) Junkyardspecial 10) nazc0 11) incubus3612 12) D10 04G 13) G35Papa 14) Lowerd4lyfe 15) G35Luv 16) VstyLe09 17) ntoxtiger 18)G35SedanGrn 19) XDR-V35 |
this should also be in the coupe section
Is there a temp fix for this? I noticed mine goes out intermittently. It fixes when the car is shut off for a bit.
unless it's dark out how do you know when its out (especially intermittent)?... iirc you can see the illumination in rear-view mirror at night, but I dont think mine can be seen in daylight (I'm referring to in mirror of course).
^ yep thats the only way I can see mine too lol
That's how I see...but I can also see cuz when I park at work I back up to a window. Also, when in traffic, if a big truck or bus with chrome grill ismbehind youl you can see as well.
Mine is humidity related. Humidity goes up, light doesn't work. It dries out and tinworks. Now that winter is here, it works all the time. But during the humid summer, it never worked unless a cool front came through |
I wonder if mine works? :icon43: Now I guess I have a reason to drive it more :D (but I'll probably forget to look)
I work night shifts (driver at Jimmy Johns!) and Notice it a lot. It has no real precursor, it just randomly will be on or off. Also, during the day I can see a slight hint of red if its working or not or when im in my garage I can see it too. I Noticed this problem on some LED's KIA suv's use. I wonder if they have the same part failure.
^I see why they are speedy fast lol doing it in the G!
Originally Posted by Wannabe6MT
(Post 5465892)
