Drive belt sizes
Old Nov 30, 2010 | 05:11 AM
KBTOPDOG's Avatar
Drive belt sizes
Tried searching for my answer but no luck. I was going to order my belts online for my 2005 g35x and realized that some places had two different sizes for one of the belts. The smaller belt is 945mm, but the larger belt is either 1175mm or 1180mm. Does anyone know which is the correct one for my X. Thanks.
Old Dec 1, 2010 | 12:29 AM
mkvl127's Avatar
get them from your closest infiniti dealer..i paid 40$ for both belts..
Old Dec 1, 2010 | 11:01 AM
blazeplacid's Avatar
take your belt off, and if you can still read the numbers almost any autoparts store can cross reference a number
then look at the paper packaging that has the belt info, some companies put the length of the belt on the "wrapper"
but honestly, either one will work 5mm is not much and you will have enough adjustment to make either one work
Old Dec 1, 2010 | 11:44 AM
davidm99's Avatar
20 Year Member
Sedan
This thread should help with your question regarding two different size belts.
https://g35driver.com/forums/g35-sed...ion-sizes.html
But the compressor belt for your X should be the larger one since the smaller one is only used for sedans built pre-10/2002.
Old Dec 2, 2010 | 03:25 AM
KBTOPDOG's Avatar
Thanks for all the advice, I guess I'm on my own. Was really looking for a sure answer from someone that knew.
Old Dec 2, 2010 | 12:57 PM
mkvl127's Avatar
why do you need the sizes..just get them from your closest infiniti or nissan dealer..imo belts is something that you should stay oem with..some people have had problems with aftermarket belts..i just changed my belts 5k miles ago..i had 70k miles on my stock belts..after doing them you will prob want to tighten them up a little more after a thousand miles because they may stretch a bit
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
wuppiedog
Aug 7, 2015 11:16 AM
Cam_Cooper3
Aug 4, 2015 01:53 PM
