if i get s techs will i rub?
Old Dec 25, 2010 | 02:01 PM
Cody's Avatar
245/45/18 are my tires. if so i will settle for h techs.
i don't like how high the car is in the front compared to the back. i want it to even out, and also have a little bit of the 'lowered' look. i don't have money for coilovers right now. also i did have new front control arms put on to adjust camber so i should be good.
basically i wanna go as low as i can without rubbing and buying new tires
Old Dec 25, 2010 | 02:10 PM
JBF's Avatar
JBF
how many threads are you going to start that have already been answered in MANY other threads????
use the search function PLEASE
Old Dec 25, 2010 | 02:12 PM
toymachine2009's Avatar
Lol
Old Dec 25, 2010 | 02:16 PM
Cody's Avatar
i couldnt find anything with 245/45/18 measurements and rubbing. most have skinnier tires
Old Dec 25, 2010 | 04:46 PM
geesteezd's Avatar
Most likely your wheels will tuck in after the drop and you may not rub. You may want to pick up camber kits too
Old Dec 25, 2010 | 04:48 PM
Are you getting G35 S-tech or 350z S-tech?
I have not heard of anyone rubbing on springs unless they were cut to be made shorter but I dont believe there are any springs lower than 350z S-tech.
Old Dec 25, 2010 | 04:58 PM
Cody's Avatar
I would probably go with the g35. I read it will lower the front more than the back so it will even out the gap
Old Dec 25, 2010 | 05:00 PM
Cody's Avatar
Now I'm considering the h tech even more because I don't wanna have to put money into rolling the fenders and such
Old Dec 25, 2010 | 05:52 PM
you wouldnt put $50 to rolling the fenders to have a nice lowered car? to me $50 to do it is SOO worth being lower.
I am on 350z S-tech I never rolled fenders for a year and I have the EXACT same tire size you do.
When I got camber kit and toe bolt a year and a half later I got my fenders rolled when they installed the camber arms and toe bolts
You tend to be an over thinker I can tell. I am like that too sometimes but in the end it always works out when you just go for it and RELAX.. get your S-techs everything will be fine
Old Dec 25, 2010 | 05:57 PM
Cody's Avatar
I thought rolling them would cost like a couple hundred. Is the gap in the front and year tires the same? Any pics of your car?
Old Dec 25, 2010 | 06:01 PM
did you actually get a quote yet?? Find out your prices stop assuming things and there is a whole thread on Sedans with different suspension setups!
Old Dec 25, 2010 | 06:06 PM
CandlestickPark's Avatar
ill Sedan
OP where are you located? Rolling your fenders won't be anywhere near a couple hundred bucks.
Old Dec 25, 2010 | 06:09 PM
Cody's Avatar
I live in phoenix arizona. Someone told me it would cost a couple hundred. But my main priority is lowering my car so the fender is right above the tire so there's not much space. I hate hate hate how the front is so high compared to the back. I'm wondering if I get springs if it'll lower it all and the front and back still won't be even
Old Dec 25, 2010 | 06:12 PM
did you look at the suspension thread??? if you want to lower it to loose the wheel gap H-techs will not loose the wheel gap just make it smaller. I pretty much lost my wheel gap with 350z S-techs
No more wheel Gap
Old Dec 25, 2010 | 06:13 PM
Cody's Avatar
Sweet. And the rear wasn't too low?
Ill look into g and z s techs
