Squeaking Like noise
Old Dec 31, 2010 | 07:13 PM
Antoniog35's Avatar
When i turn left some times i hear like the old truck no good suspension noise. It dose it more when its cold. Maybe i need new springs or shocks ?
Thanks !
Old Dec 31, 2010 | 08:26 PM
007JD's Avatar
mayb bushings... idk
if its the same noise i have but i had put it on the left
i notice i need to replace my control arms bushing
so maybe that will take away the squeak\\
i could be a 100% wrong tho lol
Old Dec 31, 2010 | 09:11 PM
Tollboothwilley's Avatar
compression rod bushings are going bad
do a search, then replace them You can just replace the bushings, but you might consider getting the upgraded ones, from SPL or Whiteline? I can't remember the manufacturer...search and you'll see this is a very common issue.
Old Jan 1, 2011 | 12:25 PM
GreenPenguin's Avatar
Is there any harm in not replacing them right away? I too can hear a squeak, especially when going over humps at low speeds, but its not THAT irritating that I want to fix it right away. (it sucks working on cars when its freezing outside...)
Old Jan 5, 2011 | 09:48 AM
OKStateG35's Avatar
Not necessarily true. I had my compression rods replaced last year and I still have some squeaking in my suspension on cold days. I'm guessing it's control arm bushings or something similar.
Old Jan 5, 2011 | 10:31 AM
Dacket84's Avatar
I get the same noise from my front. It's almost embarassing when going over speed bumps. lol I'm not too worried about it right now as sometime in the future I would like to lower my car so it'll be dealt with then.
Old Jan 5, 2011 | 11:24 AM
G35Papa's Avatar
It could also be the sway bar bushings or the inner lower control arm bushings. Hard to really say without taking a look.
Old Jan 5, 2011 | 02:35 PM
OKStateG35's Avatar
It really is embarrassing sometimes. My car sounds like an old truck.
Over time I plan on replacing all of them with Whiteline polyurethane bushings so hopefully that will fix the problem.
Old Jan 6, 2011 | 03:21 AM
xxxxxxxxxx's Avatar
yeah the sound it makes is annoying as fawk , is it easy to change the compression rod brushing? i need to change my front right one
Old Jan 6, 2011 | 10:09 AM
blazeplacid's Avatar
my side skirts make the sound
I thought it was suspension also
try pressing in on the side skirts and see if the noise is repeated
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
