electric drivers seat is off track
Old Jan 10, 2011 | 01:58 PM
mjordan211's Avatar
when i sit in the car and the seat moves it is off track. it does not go forward or backward it turns to the side. Can anyone assist me without me going to the dealer for them to look at it.
Old Jan 10, 2011 | 02:03 PM
cremaster's Avatar
i've had this same issue and had it fixed 3 times through the dealer and it's about to go out AGAIN. it's covered under warranty.
Old Jan 10, 2011 | 02:45 PM
Matzo Ball's Avatar
I have the same problem and had the dealership check it out. One of the motor mounts needs to be replaced. $990 total cost. Fvck that.
Old Jan 10, 2011 | 07:04 PM
mjordan211's Avatar
thanks for the info, cant afford the motor mounts to be replaced right now. Will have to drive in this condition for awhile.
Old Jan 10, 2011 | 08:11 PM
Blue Dream's Avatar
I drove ttrank's car solo
https://g35driver.com/forums/g35-sed...ght=Seat+track
https://g35driver.com/forums/interio...ght=Seat+track
These should help, sounds like a stripped gear might be your problem.
Old Jan 11, 2011 | 12:45 AM
DKatman's Avatar
I had the same thing and I went to odometergears as of those threads discusses. It was brilliant. $65 and solved my issue perfectly. I am sure it will happen again. You can just take off a few bolts to see if that is the issue you have.
Good Luck,
Dave
Old Jan 23, 2011 | 05:40 AM
Blue Dream's Avatar
OP any resolution to your issue with the seat?
slider_ua
Jul 29, 2015 04:17 PM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
brian_z
Jul 20, 2015 01:30 AM
