Heat/AC not blowing ANY air g35 coupe
Old Aug 2, 2021 | 10:28 AM
QX1's Avatar
QX1
Blower motor bushings were replaced but blower does not work anymore
Bushings were replaced but it does not work?
Old Aug 5, 2021 | 09:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably the relay that's BEHIND the cabin fuse box Fuse Block - J/B.
Remove the plastic trim over the fuse box, not just the little access window the whole plastic piece.
Unbolt the two 10mm nuts that hold the fuse box to the chassis, lift it forward and you will see some blue relays. One of them is the AC relay for your AC blower motor.
Autozone carries the OEM Nissan relays usually.
Old Aug 6, 2021 | 02:53 AM
QX1's Avatar
QX1
Not true. I installed new blower, everything works fine. The bushing were replaced and it made it unfunctional. The car is 15 years old.
champppy
Mar 31, 2020 12:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
ZacDesu
Jul 14, 2015 11:13 PM
