Found a good deal on tires, will they fit??
Old Jan 17, 2011 | 01:43 PM
4D05G35's Avatar
I am wondering if this set-up will fit without issue.
05 Sedan with G/Z springs and Tokico shocks
19x9 + 35 front. 245/35/19
19x10 +45 Rear. 285/30/19
The tires are Toyo Proxes T1R. I'm okay with rolling the fenders, but thats about it.
Thanks.
Old Jan 17, 2011 | 06:02 PM
Tollboothwilley's Avatar
Front should fit - might rub a bit
Rear will need spacers(+10), neg camber, and rolling of the fenders i believe
Old Jan 17, 2011 | 06:32 PM
4D05G35's Avatar
What If i didnt add the spacer and Neg camber?
I dont really want to run a bumch of neg camber, I would like to stick close to stock.
I am currently running 19x9.5 +40mm w/255/35/19 in the rear and I am fine without rolled fenders. If I have done my calculations correct I should only be pushed out 1mm from the location of my current wheels. The wheel itself I'm not worried about, but the width of the tire that im unsure of.
*Now that I have put more thought into the new tire(285) will in theory be pushed out 16mm more than my current (255). So I need to measure to see how much room I have between the tire now and the fender*
Does that sound right?
Thanks
Old Jan 19, 2011 | 11:15 AM
DFESPINOSA's Avatar
Hello, Maybe I'm not using the search correctly, but i couldn't find the answer to my question. Can somebody tell me if OEM 19" Infiniti G37 rims factory, made by Enkei, Two front rims are 19x8.5 with offset 43. The rear rims are 19x9 with offset 45. will they fit my 2007 Sedan G35x ?
Old Jan 19, 2011 | 01:54 PM
LuXXXz's Avatar
Thanks.
should be perfect w/ those offsets the tires might rub on big bumps but while driving should be good. w/o rolling fenders
nice and flush and you're only on g/z springs
Old Jan 19, 2011 | 02:38 PM
4D05G35's Avatar
awesome! Thank you very much. I test fitted the front yesterday and im really happy with how it fits. The rears should be here tomorrow.
Old Jan 19, 2011 | 03:17 PM
4DGS's Avatar
You'll be fine, roll your rears.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
teamghost
Jul 28, 2015 04:52 PM
