Tire Pressure sensor. Sensitive????
Old Nov 1, 2004 | 07:50 PM
silver04's Avatar
"G" Spot
This morning while driving my car their were no warning lights.
But, we had a front move through this afternoon and when I left from work the temp had dropped probably 15 degrees or so. When I started driving in the parking garage my TPS went off and stayed on.
I guess I need to inflate my tires due to the cold air causeing low pressue. Is that correct.
I have a 04 sedan with sport rims and tires, anyone know the needed pressure off hand.
thanks
mike.
2004 G35 sedan. Silver/graphite, Premium, sport, aero package. Z-tube, K&N
Old Nov 1, 2004 | 08:23 PM
Britishbloke's Avatar
Re: Tire Pressure sensor. Sensitive????
35 psi, cold.
Old Nov 1, 2004 | 08:36 PM
ABQ_G35's Avatar
The sticker on my car calls for 30PSI.
Brilliant Silver/Graphite/Premium/Chrome Wheels '04 Sedan/5AT
Old Nov 2, 2004 | 07:51 AM
shads's Avatar
The other morning mine went off also. 28 degrees here in MA. So I got out and checked tire pressure... 26 psi cold. I checked the pressure with hot tires... 30 psi exactly. The sticker on my 04 6MT calls for 30. I bumped the hot pressure up to 32 psi. 28 degrees again this morning and no tire warning.
Old Nov 2, 2004 | 09:07 AM
silver04's Avatar
"G" Spot
Sweet thanks guys.
I haven't been able to add more air yet...been raining hard here in Houston. It will let up today and then I'll do it.
I guess i'll do 30 - 32......just in case it gets warm again.
thanks
mike
Old Nov 3, 2004 | 09:50 PM
Noremac's Avatar
The FSM quotes the following for 2004 models.
Pressure at which visible and audible warning are activated:
Coupe: 28 psi
Sedan: 24 psi
There is no mention of a warning function for an over-pressure condition.
The reason, of course, that many people are getting the warning light is the drop in outside ambient temperature. How much does temperature affect tire pressure, you ask? A quick calculation shows that a tire a 70-degF will lose 5 psi if cooled down to 10-degF.
<font color=blue>'04 G35S 5AT, Black Obsidian/Willow, Prem/Nav/Sat</font color=blue>
Old Nov 4, 2004 | 09:10 AM
Streaker's Avatar
When I picked my car up at the dealership the ride was harsh. It was about 100 miles before I got the chance to check the tire pressure using a digital gauge. They were at 35psi. Infiniti calls for 30. My butt seems to agree with them. Thirty gives me a good cornering without feeling every tar strip on the highway. Pay attention to your tire wear. If your tires seem to wear more in the centers, you are running too much air. Wear on the outer edges means the tires are too soft. This is only true if your alignment is good. Misalignment is a
whole different story .
Streaker in GA
Old Nov 5, 2004 | 01:26 PM
JerryD's Avatar
Mine sensor works fine. Just yesterday went on - I had 28psi in one tire (coupe) - pumped up all to 35 and the light is gone. Very useful!
Old Nov 5, 2004 | 06:59 PM
Xman's Avatar
Mine went off this morning too. 27 psi cold. I hear this thing beeping and it's like WTF? ...Cool
Old Nov 11, 2004 | 05:38 PM
Blue68's Avatar
One of the questions was what was the pressure supposed to be. In case you weren't aware, the manufacturer recomended tire pressure is in the driver's door jamb. They've been that way for years.
2004 G35 Coupe 6MT, Desert Platinum
1968 Chevy C10, never ending hobby
Old Nov 12, 2004 | 06:30 AM
bmoney's Avatar
I think mine is a little too sensitive. It went off the other day but all 4 tires were right around 35 psi. I pumped them up to like 40 then dropped them back down to 35 psi. The light went off minutes later. I fooled it!
05 G35C 5AT/DG/Stone/Prem/Sport/Aero Kit
Old Nov 13, 2004 | 11:07 PM
G35Papa's Avatar
Does anyone know if the TPS came with the 2003.0 models? Or if it was first introduced in the 2003.5 or 2004 ones?
Thanks
<font color=orange>G35papa</font color=orange>
2003 Pearl White - Premium Willow - Clear Corners (moded) - Z-tube - 18" OEMs- Tinted all around
Old Nov 14, 2004 | 06:06 PM
Gordgee's Avatar
Administrator
I believe it was introduced for the 2004.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Nov 15, 2004 | 04:41 PM
G35Papa's Avatar
Thanks for the info gordgee!
Mry
Mar 3, 2023 01:03 AM
Danielek
Sep 20, 2015 12:08 PM
JoeMac
Aug 20, 2015 10:17 AM
