BCM going bad?
Old Aug 27, 2015 | 11:39 PM
Danielek's Avatar
BCM going bad?
I recently purchased an 05 AWD sedan and i absolute love how the car handles....wow....very impressed actually. The car has some electrical issues though that i would love to fix since i enjoy working on my own wheel like most of us...
The sues are:
- Power mirrors dont work
- sunroof is dead
- NAV screen wont come up. ( i did recently changed the DVD player and i know it works and spits out a DVD)
- recently changed to aftermarket rims and the LOW PRESSURE light isn't even coming on as it should since the tires are not monitored
Would it be possible for the BCM to have gone bad? Alll fuses check out and all good.
Also does anyone know if there is any way to KEEP the NAV screen up all the time so to bypass the screen motor?
Please someone direct me in a right direction since i am falling in love with the car
Much appreciated.
Old Sep 3, 2015 | 03:10 PM
Danielek's Avatar
Does anyone has any comments or suggestions?
Old Sep 20, 2015 | 12:08 PM
RA102223's Avatar
If all fuses check out, then it very well could be the BCM.
It might be a long shot, but check the ground points in the engine. There's only about 5. I've done a lot of my own stuff, and with only a single ground lose/ off it screwed up a bunch of electronics in the car. Should only take a few minutes to make sure they aren't covered in corrosion or broken off.
I don't have nav so not sure about that.
Good luck
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
