Weird Noise When AC/Heat Is On
Old Jan 18, 2011 | 09:34 PM
jdubbyap's Avatar
Originally Posted by LuXXXz
yeh i dunno buddy i had a noise like that when i had the ac on, it was like a crackling noise, crackling grinding. good luck man! i hate trying to find a problem life is so much easier when you know what the problem is and you just have to fix it, but diagnosing it sucks
Thanks for your input. I believe it is in the fan below the cabin air filter, but I'm not sure I am capable of disassembling it and putting it back together. It's either that or something close to the firewall under the hood. Are there any components that move behind the center of the dashboard when the air is on?
Old Jan 18, 2011 | 11:10 PM
kpowe1's Avatar
I have an 03 sedan and it makes this type of noise when i cut the car off, it make this noise about 75% of the time with the ac off and sometimes while driving for a little whil. I have 163,000 on the car, the ac compressor a little loud when i cut it on.
Old Jan 19, 2011 | 01:46 PM
LuXXXz's Avatar
you can take out the head unit and see if there is anything around there you can reach. i had to replace my cd player cause of the famous cd fo error
its not a lot of work try it there should be a diy for removing the HU
Old Apr 13, 2011 | 07:42 AM
jwrape's Avatar
Mine was doing this last fall and I went and cut the belt off one day and it stopped. Now I gotta figure out how to get the A/C Clutch off to replace it.
Anyone know if they come off easy or they are stubborn like others I have attempted
Old Mar 14, 2018 | 04:02 AM
SteveGranger's Avatar
Mine was done by ac unit installation expert last month and after that i never felt any noise in my ac unit.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
