FSB Install on a '04x...
Old Jan 23, 2011 | 01:24 PM
Matzo Ball's Avatar
Question FSB Install on a '04x...
What do the bolts for the struts/mounting braces need to be torqued to when installing?
Old Jan 23, 2011 | 03:52 PM
TurTLe*'s Avatar
there is a torque spec for it but just apply common sense. This isn't a make or break type of thing.
Old Jan 23, 2011 | 05:17 PM
Blue Dream's Avatar
I drove ttrank's car solo
35-42 ft/lbs on the 05 2WD.
Old Jan 23, 2011 | 09:52 PM
Matzo Ball's Avatar
dont like screwing with suspension pieces.
hmm, similar for the X?
Old Jan 23, 2011 | 11:10 PM
drkay's Avatar
Probably
Old Jan 24, 2011 | 07:09 AM
TurTLe*'s Avatar
this is hardly a suspension piece. This is like hanging a sign on a door.
If it was that IMPORTANT it would of came STOCK on the car like a 350z. This is about the same as torque setting on lug nuts, should be somewhere like 78-90ft. lbs on the lugnuts. if you put it at 125 its not a big deal. but at 200 you MIGHT warp the rotors. I understand your worry but adding a peice of suspension can cause negative or postive feedback.
Either use the tq spec given to you for the 3 top nuts, which should be exactly the same for a 350z/G coupe/ RWD/ AWD, its 3 nuts that hold the strut to the body of the car. As long as its tight it doesn't matter.
Old Jan 24, 2011 | 01:34 PM
Matzo Ball's Avatar
appreciate the help! Just want to be sure.
Old Jan 24, 2011 | 04:59 PM
Blackout713's Avatar
let us know if you have any problems with the install. it's pretty straight forward
Old Jan 25, 2011 | 11:54 AM
G35Papa's Avatar
Don't over tighten the bolts, they tend to strip easy when removing them from being over tightened. I had to cut 2 off in the past and it wasn't fun lol
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
