Rear FD 3.54 Problem!!! (P1574)
Old Jan 25, 2011 | 10:55 AM
NFSP G35's Avatar
? = 2B || !2B
^Neither of those is going to happen.
Most you'll lose will be your cruise control.
Old Jan 25, 2011 | 11:02 AM
kyemaul's Avatar
In that case ....screw cc... I want powa!!!!
Old Jan 25, 2011 | 11:47 AM
DaveB's Avatar
Originally Posted by NFSP G35
Changing the overall diameter of your rear tires is similar (though not quite as dramatic) as changing your FD ratio.
A smaller diameter tire shifts the true "final" ratio in the same direction as when you swapped from a 3.33 to a 3.54
So really, you're even more than a 3.54 so to speak.
Bingo. I have a set of 23.5" tall 225/50R15 BFG drag radials I plan on running this spring. The tires are nearly 3" shorter than the OEM 215/55R17s. Paired with my 3.54 gear, the effective rear ratio will be nearly a 3.8. The wheels and tires also weigh about 20lbs less each too.
Old Jan 25, 2011 | 12:01 PM
G35Papa's Avatar
Originally Posted by kyemaul
Ok i understand, that explains sometimes on the highway i can set my cruise
control and sometime I can't. I would like someone that has my yr and the 3.54 and different tires to chime in. Not to say your not helping me or giving me a better understanding. Have your heard of this issue or anything to resolve this issue.
Also is the TCM which i think is the tranny cpu connected with that because my car gave a tcm code but later disappeared ????
235/30/20 front
255/35 rear
3.54 gears
2003.0 old *** g
no cel
Old Jan 25, 2011 | 01:07 PM
kyemaul's Avatar
Originally Posted by G35Papa
235/30/20 front
255/35 rear
3.54 gears
2003.0 old *** g
no cel
i dont understand how? do you remember what yr 3.54 you have did you get 03 6mt one?
Old Jan 25, 2011 | 01:11 PM
G35Papa's Avatar
Mine was out of an 05 coupe IIRC
Old Jan 25, 2011 | 01:13 PM
procustomize's Avatar
Ouch...
Old Jan 25, 2011 | 01:19 PM
kyemaul's Avatar
Mine was out a 05 sedan 6mt so i do and i dont understand y a cel light for me the diameter on your tire is more than mines. Can the tcm be reset?
Old Jan 25, 2011 | 01:26 PM
kyemaul's Avatar
I understand what thoes guys was explaining to me. What i dont understand is that I never read about this. Several other people have done this swap, but only my G is giving me this problem. I drive hard but i know guys with this swap with turbo's and no issues. They drive crazy hard.
Old Jan 25, 2011 | 07:50 PM
G35Papa's Avatar
Has your car thrown a cel from the start of the swap? Check to make sure your wheel sensor is connected or not smashed. It runs on top of the diff.
Old Jan 25, 2011 | 08:02 PM
NFSP G35's Avatar
? = 2B || !2B
I think I've figured out the problem.
Kyemaul, your rear tires are SMALLER than your fronts, whereas G35Papa's rears are LARGER. (Talking overall diameter here, has nothing to do with tread width)
I'm crunching the numbers right now so I can show you exactly what I'm talking about.
Old Jan 25, 2011 | 08:04 PM
G35Papa's Avatar
Just grab a calculator already Ashley
Old Jan 25, 2011 | 08:16 PM
NFSP G35's Avatar
? = 2B || !2B
Ok, when you change from the 3.33 to the 3.54, you change your FD ratio by 6.3% from stock.
With OEM size tires (or tires that are equal diameter front and back) the computer will only see a 6.3% change.
Apparently, this isn't enough to throw a code.
However, your rear tires are 1.3% smaller diameter than stock.
That brings you to a 7.6% difference. Basically the same as having an equivalent FD ratio of 3.59. Likely still not enough to freak out anything... until you factor in front tires...
Your front tires are actually 1.4% larger than the OEM diameter, throwing the imbalance up to 9% which is apparently enough to trip the computer out.
Consider that with this difference, when you're close to 90mph the car thinks it's front tires are going 10mph slower than it's back tires.
In Chris' case, the difference in tire diameter (though greater) actually works in the opposite direction because the larger diameter tires are on the back, not front.
Again, starting with the same 6.3% discrepancy from gear swap:
Chris' back tires are 2.7% larger than stock, bringing his equiv-FD down to a 3.44 and the difference to 3.6%
Then, factor in his fronts are actually 2.9% smaller than stock diameter, so that brings the driveshaft/front tire difference down to only 0.7% from the expected ratio.
So Chris computer barely sees any difference at all from what it was stock despite the rear end swap.
Old Jan 25, 2011 | 08:17 PM
NFSP G35's Avatar
? = 2B || !2B
^ I used one. It was still a lot of math
Old Jan 25, 2011 | 10:51 PM
  #30
G35Papa's Avatar
I'm a damn good guesser
