Rear FD 3.54 Problem!!! (P1574)
Old Jan 25, 2011 | 11:52 PM
  #31
GAU-8's Avatar
Won't this also make VDC go nuts? I thought if you wig the computer out like that it kills CC and VDC goes crazy trying to keep the car under control.
Old Jan 26, 2011 | 10:20 AM
  #32
kyemaul's Avatar
Originally Posted by NFSP G35
^ I used one. It was still a lot of math
Thanks man I'm going with 19s rims what tire size should I go with to get the right ratio to not meake my ecu go NUTS I hate CEL lights....
Old Jan 26, 2011 | 10:29 AM
  #33
NFSP G35's Avatar
? = 2B || !2B
Can you swap your front and rear tires without rubbing?
I know the widths will be all wrong, but at least youll know if thats the problem
Old Jan 26, 2011 | 10:37 AM
  #34
kyemaul's Avatar
Ill try 245/45/18 in the front shouldn't rub I'm. Not dropped. theses same tires came off my bros G coupe 05 A/T
Old Jan 26, 2011 | 10:47 AM
  #35
onthe3rdday's Avatar
Swapping front to back will be a waste of time. His rears are not smaller than his fronts. He claims 225/45 front 245/45 rear. His variance between sizes is pushing it @ 2.7% in a Sedan. The sedan computer wants to see a 26.3" tire all around. Something close to that diameter or with stagger fit, something less than 2.0% variance might fly. Putting 245/45's all around should be enough to solve this problem.
Old Jan 26, 2011 | 11:41 AM
  #36
Dan in St Louis's Avatar
Let the machine do the math for you -- attached. There is nothing quite like having real numbers.
File Type: zip
Old Jan 26, 2011 | 11:55 AM
  #37
Tollboothwilley's Avatar
This is a common issue for some people when going from a 3.3 FD to 3.5. It is what happens to me ONLY when i exceed 85 mph during my driving period.
This code simply prevents the ECU from allowing Cruise Control to be set.
If I get up to speed and just set the cruise at 80-83 mph everything works fine. There are no issues from this code other than the CC.
Old Jan 26, 2011 | 12:03 PM
  #38
If you are like me (early 2003) then tire size really isn't the problem. Its the way the speed sensors in the trans and FD get compared in the TCM.
Although i trip the P1574 when i go over 85 mph, it always resets after i turn the car off and doesn't affect me the next time i drive if i want to use my CC - and it NEVER turns the CEL on with that code.
This issue was long discussed in the Drivetrain section in a 20+ page thread.
Later years have a different TCM which may not compare both speed sensor inputs - just goes off transmission speed for CC and diff speed for Speedometer. Most likely just one of the many things that was changed after they made the early 2003. LOL
Old Jan 26, 2011 | 12:28 PM
  #39
NFSP G35's Avatar
? = 2B || !2B
Wait, sorry
Disregard my advice on swapping the front and rear tires. I looked at the post wrong. You already have the larger diameter tires in the back.
Old Jan 26, 2011 | 05:25 PM
  #40
kyemaul's Avatar
Just fixed it changed my speed sensor set problem presist with setting cc over a curtain speed but no more codes!!....
chinee
Jun 10, 2024 07:48 PM
atk08
Jul 30, 2015 03:12 PM
wojowojo16
Jul 27, 2015 09:57 AM
Soumilg
Jul 18, 2015 12:33 PM
