Salvage g35 - how to tell frame damage??
Old Jan 28, 2011 | 12:32 AM
Mb6347's Avatar
Hi, I just bought an 04 infiniti g35 with a salvage title. It was a side impact and the pass door was replaced and part of the quarter panel also replaced. How would I know if it had frame dmg? The auto check said none, it drives straight and feels real smooth. What can I look for? Will my tires wear differently? I looked online and it said to look for frame clamp marks but what does that look like??
Any help is appreciated! Thx!
Old Jan 28, 2011 | 12:50 AM
007JD's Avatar
put the car on a left .. or jack it up .l..
if theres allot of welding or bent or curv or the frame then u know
( a little advice .. if your not a 100% sure on salvage title. i wouldnt recom. buying them)
they have a issue of having trouble down the line
some do ..
some dont
but heads up
Old Jan 28, 2011 | 01:01 AM
Mb6347's Avatar
Maybe I'm looking at the wrong thing underneath my car, is the frame those long pipe looking things that curve? Or there's like straight gray bars type things? Sorry! I'm a girl and I'm not too car savvy. I did have a friend who works on cars look at it before I bought but I want to see for myself.
Old Jan 28, 2011 | 01:09 AM
gtivr698's Avatar
Those long pipe looking things that curve will be your exhaust Don't worry if the car drives straight and feels smooth most likely there isn't any frame damage.
Old Jan 28, 2011 | 01:12 AM
xxxxxxxxxx's Avatar
another girl on g35driver? whatttt lol
Old Jan 28, 2011 | 01:39 AM
Mb6347's Avatar
Yes, I wanna learn allll about my new car!
Old Jan 28, 2011 | 02:07 AM
4D05G35's Avatar
Welcome, you found the right place to learn all about your car.
Did you have any shops check out the car prior to the purchase? Or just your friend?
Old Jan 28, 2011 | 09:17 AM
Mb6347's Avatar
Well just my friend but he used to do body work at a body shop a few years back and he buys salvage cars all the time. So I thought that was good enough, but I started noticing some creaking when I drive on the side where the impact was, kinda from the trunk :|
Old Jan 28, 2011 | 11:10 AM
VincenzG35's Avatar
when buying a car rule #1 never buy salvage or flood titles no if ands or buts i could have got an 08 sakvage for the same price as my 03 i didnt even think of it just a bad idea
Old Jan 28, 2011 | 01:20 PM
007JD's Avatar
i would never say never on buying a salvage
i would say be smart or be very careful
and the frame is the square looking type rods .. usually black or rusty color lol
and yea you can learn allot from here..
just do the search and read,,
read allot
Old Jan 28, 2011 | 01:39 PM
Jeff92se's Avatar
Red Card Crew
Just a note. It wouldn't necessarily require a an 04 to have frame damage to deem it a salvage. Given how low our cars are valued at now. Only a bodyshop is going to be able to tell what damage it had. That is if they actually care enough to inspect it well enough
Old Jan 28, 2011 | 02:47 PM
StratagemII's Avatar
I was told by my bodyshop after my accident & same question that most newer cars including G are unibody construction i.e. no frame rails like a truck, every part is dependent on each other Am I misinformed ?
Old Jan 28, 2011 | 03:09 PM
Mb6347's Avatar
Thats what I've heard, the car had a unibody frame. Am
I able to tell just by driving it? My car drives Soooo smooth, you would've never thought it had been in an accident. Also I wondered that, if it's deemed salvage that automatically meant it had frame damage?
Old Jan 28, 2011 | 04:03 PM
ray1370's Avatar
What he said.
Old Jan 28, 2011 | 04:14 PM
007JD's Avatar
they would still have a chasis im assuming ... im not sure.. but if it had any major problems
you would see some major welding work on it
and the squeaky noise is probaly ... the bushing going bad
it happens to our car allot
and i read on your other forum
that the crash was on the rear... well i would say if any car was hit majorly in the front end or rear. 2 be careful ...
front end because of motor.. motor displacement and such
and rear.. because our car are rear wheel drive .. and axel . can i 4 got the name of the part
but it looks like a long pole and it turns... and taht can also get messed up
but if you had someone check it out .. and everything was fine.. then
just for now drive it until something happens.
and if anything does happen go back to where you bought it
idk what laws u have in your state or country but depending
there could be a lemon law
but you have to remeber it is a salvage title..
so there were probaly selling as is
