04 sedan heater only works above 2000rpm
Old Feb 2, 2011 | 02:47 AM
devin7632's Avatar
hi i have an 04 g35 sedan and the heater only blows hot air above 2000rpm. when the car is at idle it blows freezing cold air. when i am on the freeway it blows hot air. please help
Old Feb 2, 2011 | 08:35 AM
drkay's Avatar
I had the same problem. I had let the coolant level go too low and air got into the system. Check the coolant level in the overflow reservoir.
Old Feb 2, 2011 | 10:10 AM
thescreensavers's Avatar
Mr.202?
^ +1
you possibly have air in the system
Old Feb 3, 2011 | 11:56 PM
devin7632's Avatar
ok i put coolant in today and it was really low. but my heater still doesn't work at low rpms. i think i may have air in the system. how do i get this air out? please help
Old Feb 4, 2011 | 01:09 AM
drkay's Avatar
How low was the fluid? My reservoir was actually bone dry and a lot of air got in. So much that I actually had to fill it to max a couple of times after the car cooling down before the heater began to work normally.
Old Feb 4, 2011 | 01:25 AM
Mr.202?
There is a screw in the back that is used to get the air out, its next to the ATF dipstick. Next to the battery compartment.
I am not sure how to do it, Search around.
Old Feb 4, 2011 | 05:46 PM
5150DS's Avatar
https://g35driver.com/forums/g35-sed...eo-series.html
Old Feb 8, 2011 | 12:24 AM
devin7632's Avatar
thank i just put coolant in and my heater works. i just dont understand how i was that low on coolant
Old Feb 8, 2011 | 12:28 AM
Mr.202?
^ eh, leak or your engine is eating, you should get your oil tested and or look for green puddles.
joedaddy1
Jul 28, 2015 02:58 PM
Rehman2009
Jul 27, 2015 03:23 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
hrdwirk1
Jul 14, 2015 05:46 PM
