Taking off my Rear spoiler and emblem this minute Pics inside Need little help
Old Feb 3, 2011 | 07:12 PM
toymachine2009's Avatar
First question is I have my spoiler unbolted.. Its just hanging by a wire.. Where do I disconnect the wire at.. I dont really wanna cut it for if I sale it or whatever.
2nd question is im trying to remove my infiniti emblem on the back.. I removed the liner under the trunk and I dont see a bolt for it
Old Feb 3, 2011 | 07:13 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
There is no bolt for the emblem. It's just double sided tape. Heat it up with a blow dryer/heat gun and run dental floss between the emblem and paint. Then use goo gone or wd40 to remove the excess tape.
Old Feb 3, 2011 | 07:14 PM
What seriously??? I was always told their was a bolt their this whole time!!! damn!! I am going to go take that emblem off right now then..
Old Feb 3, 2011 | 07:20 PM
xxxxxxxxxx's Avatar
wen i took off my spoiler i cut the wire lol
Old Feb 3, 2011 | 07:25 PM
Frankieg35's Avatar
I think it unhooks under the rear decklid.. Going wingless??
Old Feb 3, 2011 | 07:27 PM
Yes I am going wingless and I just cut them anyone wanna buy a wing...
Old Feb 3, 2011 | 07:35 PM
CandlestickPark's Avatar
ill Sedan
You do realize there are two holes behind the trunk emblem right?
Old Feb 3, 2011 | 07:38 PM
Mustang5L5's Avatar
There are holes. You will need to fill and paint but I assume you are doing that anyway
Old Feb 3, 2011 | 07:43 PM
Okay so there is holes behind it why? If it's on by 3m adhesive why is there 2 holes behind it? Yea I'll get them filled and painted when I redo whole trunk.
Old Feb 3, 2011 | 07:46 PM
mkvl127's Avatar
i think the holes r there to make sure the emblem is centered and level?..only reason i could come up with
Old Feb 3, 2011 | 10:44 PM
Mustang5L5's Avatar
Alignment.
Plenty of manufactures use alignment holes for centered emblems like that.
Old Feb 4, 2011 | 01:07 AM
DivZero's Avatar
The Infiniti emblem has two plastic guides that go into the two holes in the trunk. The guides just hold it in the right spot, the emblem is only held on by 3m tape.
Also there is a connector you can unclip to remove the spoiler without cutting the wire (really xxxxxxxxx...you just cut it!?!? lol) When you have the lining off you should be able to find it by wiggling around the wire going into the trunk. It is connected to the wiring that goes to the lock mechanism.
Old Feb 4, 2011 | 03:00 AM
Yea just cut it no biggie..
Old Feb 4, 2011 | 03:32 PM
DivZero's Avatar
Did you secure the loose end? Lord knows we don't need any more rattles.
Old Feb 4, 2011 | 06:01 PM
Yea I did.. JW does $320 sound about right for them to weld all holes shut including ones where the infiniti emblem went and paint trunk?
Also thinking about molding a m3 lip while they are doing all that might as well right..
