Trunk problem. Help!
Old Feb 9, 2011 | 10:38 PM
dakiddanthony's Avatar
Hi. I'm a G newbie. Just got my 03 sedan 5AT a week ago. When my keys are in the ignition I don't know how to open the trunk unless I turn the at off, take the key out and press the trunk release.(key fop doesn't work when in ignition) this is pretty annoying. To my knowlege there's no trunk release in the car and I am used to that method. So My question is pretty much how an i open te trunk while the car is running. I'm sure this is a newbie question. Please help me out.
Old Feb 9, 2011 | 11:32 PM
LuXXXz's Avatar
there is a button in the glove box if you have the doggy door press it off, its for a valet button
otherwise if its an 03.5 there is a trunk open button bottom left of steering wheel where the vdc light is
Old Feb 10, 2011 | 12:22 AM
I saw the valet button in the manual but I don't know what that actually does
Old Feb 10, 2011 | 01:20 AM
LuXXXz's Avatar
thats if you give your valet key to valet ur car then the glove box wont open w/ that key
well anyways in the glove box there is a button thats a trunk unlocker press it and youll be able to open ur trunk while your car is on and key in ignition it wont open while its in the ignition ull be able to open it
glove box key button press
Old Feb 10, 2011 | 01:37 AM
kennymo's Avatar
there is also the button to the left of the steering wheel down below. its the center button. right next to the vdc button
Old Feb 10, 2011 | 02:35 AM
Hotdawwgman's Avatar
Kenny, you beat me to it...
Old Feb 10, 2011 | 08:54 AM
I don't have that button there. It's blank
Old Feb 10, 2011 | 08:56 AM
I tried turning the switch off on the glove box and then opening the trunk while the cars running. Doesn't work. Also tried doing this while the switch is on. Doesn't open.
Old Feb 10, 2011 | 01:42 PM
LuXXXz's Avatar
i dunno did you try opening w/ the key fob or w/ the trunk open button?
Old Feb 10, 2011 | 01:53 PM
I didnt try the key fob because I figured it wouldn't work while in the ignition as usual. I will try that next then after I flip the glow box switch
Old Feb 10, 2011 | 02:25 PM
PAIXAO's Avatar
Are you trying to open the trunk while the car is in gear? I have to double check my car, but I think that if the key is in the ignition and the car is running, I cannot use the trunk button to open the trunk unless the e-brake is engaged. I have a 6MT though...
Old Feb 10, 2011 | 03:38 PM
kennymo's Avatar
is the button to the left just blank as in no picture or there is actually no button there. because there is no picture on mine but you push it down and it opens
Old Feb 10, 2011 | 04:28 PM
DaveB's Avatar
Unlock the doors.
Old Feb 10, 2011 | 04:40 PM
Eric@TCGMiami's Avatar
Originally Posted by DaveB
Unlock the doors.
Old Feb 10, 2011 | 06:54 PM
LuXXXz's Avatar
he still never answered is it a doggy door?? or the regular trunk?? 03.5
