anyone running 10w30 now/was
Old Feb 18, 2011 | 11:13 PM
TurTLe*'s Avatar
Normally I opt for 5w30 in w/e flavor is on sale that day. I wasn't looking and i grabbed mobil 10w30 this time around.
I have been thinking the car has been developing a idle pulley failure due to engine noise. But i used 10w30 today and on start up it was a lot quieter. The noise isn't 100% gone but its a lot quieter. I might be making stuff up or maybe there was other factors but i think i'll be using 10w30 from now on.
Old Feb 18, 2011 | 11:38 PM
midnytegsedan's Avatar
Yea i was running 5w-30 till i went over 100k miles, then switch to mobile 10w-30 and I've had no problems at all. It runs a lil better in my eyes
Old Feb 19, 2011 | 01:08 AM
thescreensavers's Avatar
Mr.202?
well colder temp its thicker so "starting up quicker" does not make any sense at all...
Old Feb 19, 2011 | 02:15 AM
almost3flips's Avatar
I think the OP meant quieter but yes if it was quicker with the cold temps that would be odd
Old Feb 19, 2011 | 03:52 PM
TurTLe*'s Avatar
never mentioned about quicker.... QUIETER ( its not a word but w/e)
I've been having a noise, looking around the board most likely its a bearing/idler pulley somewhere. I haven't had enough time to remove the belt and spin each on its own yet. So I've just lived with it. Since i bought the car at 30k I've been using dino 5w30 regardless of temp/conditions and etc. Now running 10w30 it seems the noise i thought was related to the pulley/bearing has been a lot less. Been switching up GTX/mobil 5000 5w30 and now running mobil 5000 10w30.
I've only heard of rare magical cases where noise has been less. I know most guys on here run all different grades/weight oils for w/e reason they have and the motor has accepted it. Just wanted to state what i noticed in my last oil change.
it doesn't start up quicker at all.
Old Feb 19, 2011 | 06:06 PM
drkay's Avatar
i run 0w-30 all year around in canada. . is that a problem?
Old Feb 22, 2011 | 07:49 PM
AuAltima3.5's Avatar
I used 0-30/40 in my 3.5 altima for over 50k miles. you'll be fine. In Canada it's more needed, I'm sure you guys see temps way below 0F. I did it only because I used German Castrol (0w30) and Mobil 0w40, which were highly lauded by the oil guys at BITOG.
The first number (usually a 0, 5, or 10) has to do with pump-ability when cold. Technically, the thinner the better but I found the DEs start a little better with just 5w and a good filter (OEM, Mobil).
Old Feb 22, 2011 | 08:45 PM
Mr.202?
Lol your right, I misread it
Thebaws11
Jul 2, 2021 11:36 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
