05-06 gen G35 SEDAN Acceration problem???
Feb 27, 2011 | 12:45 AM
Hey guys,
Ive been getting a lot of "lag" on the low end power (accelerating from 0 to 40km/h) for a couple of months.
Took it to the Infiniti/Nissan garage and they did full fuel induction and ecu reset worked for a bit. But still the same low end "lag".
But high end power seems to be normal.
Any one else having the same issue??? Any suggestions???
P.s. I still have warranty on the car up 140k.
Thanks!!!!!!
Reply 0
Feb 27, 2011 | 01:38 AM
stock, modified? how many miles? Change spark plugs?
Reply 0
Feb 27, 2011 | 02:11 PM
change your air filter and add some lucas to your gas tank and your car will drive like it was 440hp
Reply 0
Feb 27, 2011 | 02:41 PM
lucas is crap
Reply 0
Feb 27, 2011 | 08:40 PM
what is Lucas?
Reply 0
Feb 27, 2011 | 09:03 PM
^ GOOGLE IT - Lucas Products
Reply 0
Feb 27, 2011 | 11:48 PM
Quote: what is Lucas?
Snake oil
Reply 0
Feb 27, 2011 | 11:50 PM
^ haha nice!
Reply 0
Mar 1, 2011 | 09:19 AM
The car is still stock 105k on it .. Hm should I change spark plugs I was thinking of that..?
And whats snake oil? (noob question)
Reply 0
Mar 1, 2011 | 10:13 AM
If it has original plugs then they certainly need to be changed. I would have done it before the Infiniti recommended interval of 105k, especially if I was replacing them myself. Check/replace the air filter. Even though you have most likely been using paper filters, cleaning the maf sensor located behind the air filter would likely be advantageous as well.
Reply 0
Mar 1, 2011 | 10:24 AM
Quote: If it has original plugs then they certainly need to be changed. I would have done it before the Infiniti recommended interval of 105k, especially if I was replacing them myself. Check/replace the air filter. Even though you have most likely been using paper filters, cleaning the maf sensor located behind the air filter would likely be advantageous as well.
spark plugs are a good advice def going to change them asap!
And I changed the air filter 2months ago..
Thanks for the suggestions man!
Reply 0
Mar 1, 2011 | 10:27 AM
I would recommened sticking with the OEM NGK plats or the NGK iridiums if you might be partial to them.
Reply 0
Mar 1, 2011 | 11:22 AM
Snake oil is a term for something that someone will sell you to fix or cure a problem or sickness but it actually does very little to nothing at all. It was a popular way for travelling salesmen to make money during the wild west/cowboys & indians time.
Reply 0
Mar 1, 2011 | 11:29 AM
Quote: Snake oil is a term for something that someone will sell you to fix or cure a problem or sickness but it actually does very little to nothing at all. It was a popular way for travelling salesmen to make money during the wild west/cowboys & indians time.
LOL learn something new every day thanks!
and @ SLOPPYMAX, il look into the NGK spark plugs tomorrow thanks again.
Reply 0
Mar 1, 2011 | 01:45 PM
^hmm that is interesting I did not know that either.
Reply 0
