can this be trusted?
Old Mar 24, 2011 | 05:34 PM
Cone's Avatar
I need to replace thr front left wheel bearing and hub on my 2006 g35 sedan.
http://cgi.ebay.ca/Nissan-Infiniti-F...item5197eeb988
does this seem legit?
edit: also forgot to add that I went to parts source close to me, and they quoted me $305 for the bearing and hub. so this would be a pretty decent price
Old Mar 24, 2011 | 06:08 PM
georstan's Avatar
Yes it does, but are you in Canada? otherwise there are cheaper bearings online that this one...
I did both front bearings on my 2006 sedan over the weekend, simple swap, just have a breaker bar handy for some of the brake caliper bracket bolts.
Be careful with the 12mm bolt that holds the ABS sensor, clean all surfaces before re-installation.
It was the best $290 i have spent in a while car is so smooth and quiet...
Old Mar 25, 2011 | 12:51 AM
Cone's Avatar
Yes I am indeed in canada, where did you get yours?
Old Mar 25, 2011 | 08:54 AM
Mustang5L5's Avatar
I envy you rwd guys sometimes
Old Mar 25, 2011 | 09:35 AM
Project's Avatar
Seems legit. The fronts are one piece they just slip in there like Geo was saying. Nissan uses the same parts just without the infiniti dealership price.
Old Mar 25, 2011 | 12:09 PM
blazeplacid's Avatar
why not go to a local parts store and price it there?
Fedal Mogul will probably be the brand, the make some OE stuff as well as a TON of aftermarket parts
that way you will have a warranty if you need it
Old Mar 25, 2011 | 12:54 PM
Cone's Avatar
i went to a part source near my place, they quoted me 305$ for the hub and bearing
Old Mar 25, 2011 | 01:09 PM
takeitez's Avatar
you'll definitely get it cheaper online if you live in canada. everything here is so damn expensive -.-
Old Mar 25, 2011 | 01:19 PM
Mustang5L5's Avatar
Usually most of the units for sale are Timkin brand. They are an oem manufacturer....if not the oem manufacturer for Nissan
Old Mar 25, 2011 | 11:50 PM
NFSP G35's Avatar
? = 2B || !2B
http://www.infinitipartsonline.com
That is all.
Old Mar 26, 2011 | 12:53 AM
Cone's Avatar
Originally Posted by NFSP G35
Looking for the wheel bearing and hub, could not find it.
that is all
Old Mar 26, 2011 | 01:35 AM
NFSP G35's Avatar
? = 2B || !2B
^Trust me. It's there, and it's cheaper. But I ain't spoon-feeding you.
Old Mar 28, 2011 | 11:50 AM
georstan's Avatar
Mechanical Catalog - 2006 - Infiniti - G35 Sedan
Front suspension, Suspension components, Front hub, Front hub, g35, 2wd $134.36 $0.00 $134.36
This is the price i paid thru infinitipartsonline...
Old Mar 29, 2011 | 12:23 PM
Cone's Avatar
Thanx a lot, this was helpful!
Dallsinghjr1
Sep 17, 2023 11:25 AM
StephonW
Aug 29, 2015 01:24 AM
yosip1115
Aug 26, 2015 10:46 AM
