Please Help! Throttle body help
Old Mar 25, 2011 | 10:11 AM
NiGhT_ShIfT's Avatar
I tried installing the cooper throttle body heater that came with my motordyne plenum spacers, but while i was attempting to fasten the bolt with a torque wrench i heard a pop. I thought i broke the bold, but after taking it apart again, the bolt seems physically fine. Only the bold that i attempting to tightnen is not holding.
Any idea why this bolt is not holding? What can i do about this? There's no way that i can get away with only 3 bolts fastened correctly?
Old Mar 25, 2011 | 11:07 AM
Mustang5L5's Avatar
The bolt hole threads are stripped. You'll need to install a helicoil to restore the threading
Old Mar 25, 2011 | 11:24 AM
Thanks. I tried a different bold that seems to be holding. The torque wrench that i'm using is 3/8 and the socket is resting against the throttle body when i'm tightning..... Will that give me a wrong torque and cause me to over torque? I have a feeling thats what happen the first time because i had the torque wrench at 40 inch when i heard the pop.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
