Oil Change/Refill question
Old Nov 14, 2004 | 04:03 PM
pb35's Avatar
I just brought my 04 G35x to the dealer for it's first oil change at just under 3k. I came home and parked the car last Tuesday and haven't driven it since.
I went down to my garage today to clean her up a little and to check the oil to make sure it's ok. I checked and the level is between H and L. Is this ok? Should I add 1/2 a quart? If so, it's 5w/30 correct? Ironically, the oil always seemed to be at the same mark (between H and L) before I had it changed. This is why I'm asking, I don't want to add more unless necessary. I plan on doing the next change myself. Thanks!
04 G35x
Old Nov 14, 2004 | 05:21 PM
mizzoutiger's Avatar
Re: Oil Change/Refill question
You're fine. Better between lines than over or under. Continue to monitor to ensure you're not having problems. As for grade, book recommends SAE 5W-30 for all ambient temps (esp below 0F). Btw, I switched to Mobil 1 Synthetic 5W-30 at 7500 oil change.
Old Nov 15, 2004 | 05:23 PM
G35Papa's Avatar
When you go to do the oil change, make sure you remove the bottom splash guard (filter is located under it). You can get to the filter through a hole but when I tried to do it that way, oil got all over the place! What a Fin mess!
Maybe im just clumsy but ive been removing the guard ever since.
<font color=orange>G35papa</font color=orange>
2003 Pearl White - Premium Willow - Clear Corners (moded) - Z-tube - 18" OEMs- Tinted all around
jsimonk
Dec 22, 2023 03:49 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
