HELP: Problem with AC and Climate Control
Old Nov 15, 2004 | 03:51 PM
BaByBoY779's Avatar
Over the weekend, I began to experiece problems with the Air Conditioner. When set on anything except 60 (61-90) degrees with the AC on, it blows hot air if the heater is on. When you put the AC on 60, that is the only time it blows cold air. Keep in mind the AC switch is on and the same problem exist even if you put it on Auto. What do you think the problem may be? Any kind of help would be appreciated.
Old Nov 15, 2004 | 03:58 PM
BaByBoY779's Avatar
Re: Problem with AC
Please keep in mind the AC works normal only when on 60 degrees. When set to 61, 65, 72, etc, it blows steaming hot air even with the AC button on.
Old Nov 15, 2004 | 08:21 PM
FLAG35's Avatar
Re: Problem with AC
the system senses outside temp and reacts accordingly. what is your outside temp when you are trying this?
04 6MT sedan, black/willow
Old Nov 15, 2004 | 09:12 PM
BaByBoY779's Avatar
Re: Problem with AC
The temperature is normal outside, i.e. 70-75 degrees, etc. Something is malfunctioning for sure because everytime I shift the vent mode (feet, upper, etc.), I hear a strange sound from behind the dash that never used to happen before. No matter what the temperature is set to, if you put it on anything 61 degrees and higher, it blows hot air if the heater is on. When you put it on 60 degrees (the lowest setting), that is the only time it blows cold air. By the way, there is no leak in the system because it still gets cold like it is supposed to but only when set to 60 degrees. Do you think something is caught in the way preventing the expansion valve to move behind the dash?
Old Nov 15, 2004 | 10:29 PM
xswl0931's Avatar
Re: Problem with AC
Why don't you have your dealer take a look at it? It doesn't sound like it's working correctly
Old Nov 16, 2004 | 11:05 AM
BaByBoY779's Avatar
Re: Problem with AC
Before taking it to the dealer, I would like to know what the problem may be. Any ideas?
Old Nov 23, 2004 | 06:01 PM
gordhead's Avatar
Re: HELP: Problem with AC and Climate Control
I am currently working with Infiniti on this problem.
Old Nov 24, 2004 | 12:19 AM
ChicagoG's Avatar
Do you have Z tube? I heard people had problems with the AC and it had something to do with the intake.
Old Nov 24, 2004 | 06:05 AM
matters's Avatar
do you have an aftermarket intake? often times, if you do, it may be rubbing against the AC line creating a hole in it. search for the pic. its been covered in a long thread . . . hopefully its not what happened to you
matt
<font color=orange>SBC PARK</font color=orange>
Old Nov 24, 2004 | 06:09 AM
matters's Avatar
if the intake is your problem, i found the threads:
https://g35driver.com/forums/showfla...&sb=5&part=all
https://g35driver.com/forums/showfla...&part=all&vc=1
matt
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
erickLA
Aug 18, 2015 04:46 AM
TreeFiddy
Aug 10, 2015 06:50 PM
