Sqeak coming from rear! Advice needed.
Old Apr 11, 2011 | 10:09 AM
albert3029's Avatar
I've had a squeak coming from my rear brakes, does it while driving a bit but when I brake is when you really hear it. So decided to pull out one of my wheels yesterday to check my pads and noticed I have lots of meat left.
Couldn't pull out the drivers side rear due to the damn studs being too tight. On the one wheel that I pulled out, I adjusted the shim because I noticed the metal piece was close to the rotor, I bent them back a bit hoping that would make the squeak go away. Didn't work, but again couldn't pull out the other wheel to do the same.
If its not the shim or adapter, can it be a bad hub bearing or something?
Thanks for any advice!
Old Apr 11, 2011 | 11:14 AM
kayveeee's Avatar
It's your rotor, happened to me when it rains for one of my wheels.
Old Apr 11, 2011 | 12:52 PM
albert3029's Avatar
Rotor? It's a constant squeak doesn't have to be raining.
What was wrong with the rotor?
Old Apr 11, 2011 | 01:04 PM
bluedevils95's Avatar
mine only does it when it's cold. I can't wait to everything wears down so i can buy new ones.
rezendvous420
May 31, 2020 01:26 PM
JG_G35
Accessories
Feb 25, 2016 01:44 AM
atk08
Jul 30, 2015 03:12 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
nascarbuff17
Jul 16, 2015 10:23 AM
