What to do?
Old Apr 16, 2011 | 08:34 PM
DK43086's Avatar
What to do?
I know the nismo kit is discontinued, and is hard to find. I've looked at some alternative kits from some of the vendors here, but it has to be poly. Only kit I've found is through arch industries but no response from them. I found some nismo sides, and am thinking about picking them up with the stillen rear lip but would they match up or will the rear sit lower? Or should I wait for arch industries, but would the front sit lower then the sides?
Old Apr 16, 2011 | 08:44 PM
CandlestickPark's Avatar
ill Sedan
Why does it have to be poly? Are you lowered significantly and scrape quite a bit? I drive around 3-4 days a week with a FG bumper that sits less than 2" off the ground and its held up very well over the past 2+ years that I've been running it.
If you are set on poly though ARCH currently has the AIT replica in work for 03-04 Sedans. That will be your only option for a poly bumper unless you score a Nismo off eBay or a wreck yard (which is possible).
For the sides Nismo are the ones to get given the bumpers you are looking at. PM 19kdrill he'll hook you up with a set.
For the rear look into the Ionic Nismo replica rear.
https://g35driver.com/forums/exterio...ionicflex.html
Looks better than the Stillen IMO. If you like the Stillen though it will line up with the Nismo sides and AIT or Nismo front.
Old Apr 16, 2011 | 08:54 PM
DK43086's Avatar
Well Arkansas has some hilly areas and the front seems to always scrape everywhere in my coupe which is only dropped 1.5", I found a pair of nismo sides for 200 shipped, is that a good deal?
Old Apr 16, 2011 | 10:31 PM
NFSP G35's Avatar
? = 2B || !2B
^What color are they?
Old Apr 16, 2011 | 10:33 PM
DK43086's Avatar
Red, there off ebay
Old Apr 16, 2011 | 10:35 PM
NFSP G35's Avatar
? = 2B || !2B
^Oh ok, nevermind then
Always on the lookout for IP
Oh just so you know... the ones you found on eBay are from an active member here: 19kdrill.
You'll probably get a little better deal if you work with him directly... no ebay fees
