memory seat buttons are not working
Old Apr 26, 2011 | 05:09 PM
cmex's Avatar
I have checked all the connectors and all seam to be fine... is there a fuse I should check?
Old Apr 26, 2011 | 05:23 PM
TurTLe*'s Avatar
silly question, did you make sure the switch is ON...
Old Apr 26, 2011 | 05:25 PM
cmex's Avatar
there is a switch??? where
Old Apr 26, 2011 | 07:52 PM
dineth00i30's Avatar
If its a manual the hand brake has to be engaged.
Old Apr 28, 2011 | 09:41 AM
cmex's Avatar
its auto,,,, but there is the switch?
Old Apr 28, 2011 | 12:38 PM
The X Factor's Avatar
The switch that's right next to the buttons. I think it says either "auto" or "off". Make sure it is set to auto when you want it to work. And are either of the two buttons set to a position? It might have to be set before it will move the seat to that position.
Old Apr 28, 2011 | 03:54 PM
cmex's Avatar
oh,,,, now i feel stupid
Old Apr 29, 2011 | 06:23 AM
Blue Dream's Avatar
I drove ttrank's car solo
Did that fix the problem?
Old May 4, 2011 | 03:23 PM
cmex's Avatar
well , it moves back to the possition it was before,, and sttering wheel moves up so i can get out easily or something BUT if i press M, 1 or 2 buttons nothing happens,,,,, I'm not sure how it works,,,, will read the manual tonight
Old May 4, 2011 | 03:58 PM
TurTLe*'s Avatar
^ sounds like it fixed his problem.
You didn't store the settings for M1 or M2 yet. Hence why it will just give you the exit and enterance settings of your last settings.
I forgot how to set it up. Its like you set your seat, hold the store/program/set button and then hold #1 or 2 and it will store.
least you know its not broken =D
arora_g35
Apr 16, 2026 02:52 PM
tal1412
Nov 28, 2022 09:25 AM
si_driver
Interior
Jul 25, 2015 09:22 AM
apintojr
Jul 23, 2015 10:52 AM
