Alignment / Pulling to the Right / Steering Wheel?
Old Nov 20, 2004 | 01:35 PM
BrianV's Avatar
Ever since I installed my new rims/tires the car has pulled to the right. I had an alignment today, and the specs all are within range. I do have the 350z suspension as well.
Anyways, the car pulls to the right, especially on the highway. If my hands are off the wheel for more then 3 seconds I'm in the next lane.
I also noticed today that the wheel is about 4 degrees to the right when the car is going straight. If the steering wheel is straightened out then I start going left.
I guess I don't know what exactly the problem is, and I'm quite curious about the odd steering wheel inaccuracies.
Anyone have any opinions on this? I read previous alignment threads and it appears a lot of the 03's had pulling to the right problems that people couldn't resolve, but there hasn't been a post in about a year discussing it.
04 6MT Sedan - Z Tube, K&N Drop-In, 04 Z Suspension, 18x8 / 18x9 HP EVO Rims
Old Nov 20, 2004 | 02:15 PM
BrianV's Avatar
Re: Alignment / Pulling to the Right / Steering Wheel?
I just saw that my front left tire was 3 PSI higher then the other three. I lowered it to the same. I can't imagine that would make that big of a deal.
Old Nov 20, 2004 | 05:25 PM
cato's Avatar
SouthernComfort Moderator
BrianV,
I believe that if your stering wheel is cocked in order to straight,
you have an allignment issue. My old Altima was sold to me
like that. The dealer was able to make some adjustments to
get it to go straingt when the wheel was straight.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars S/H. Sport Tuned Suspension
Old Nov 20, 2004 | 05:44 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Brian..
Did you witness the alignment?
or did you get a printout of the settings?
FWIW...
You can be within specs, but if one side is minimum spec & the other is max spec then you could still have problems.
It's important that each side is the same.
& not just within spec.
<font color=blue>04 Silverstone G35, 5AT, Prem, Aero
ES100 225/45-18 front 245/40-18 rear
HKS & Y-pipe, Z-tube, Eibach, 35%Tints</font color=blue>
Old Nov 20, 2004 | 07:03 PM
BrianV's Avatar
Yeah all sides are within spec but there are variances. I guess I'll go back and tell them to make them all the same.
That's sort of what I figured.
Old Nov 22, 2004 | 06:16 PM
G35_TX's Avatar
1) Check the alignment again. It sounds to me the tech was a dummy and didn't make sure the steering wheel was straight before doing the alignment.
2) Could be a belt in a tire. I have had this happen many times. To resolve this, rotate one side at a time front to back. If it goes away, you found the problem and the side. If it doesn't go away after rotating both to the back, then you still have a alignment issue.
2004 Infiniti G35S, 6MT, Premium, Sport, DP
Mods: JDM Clears, 20% tint, Z-tube, Stilen CAI
Track: 14.32 at 98.79 mph 2.2032 60ft
Dyno 07-07-04 - 234.2 hp & 233.8 tq
http://www.g35world.com
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
