Post YOUR G35s mileage thread!
Old Jul 7, 2016 | 03:09 PM
  #1186
QX1's Avatar
QX1
just got 125200 miles on it. 06 G35 sedan 6 speed tranny. Car has had problems a lot, just changed oil in the engine. I put ELF EVOLUTION FULL TECH 5w30, AP class: SN- with newest additives. Oil is cheap 5L=35USD. I replaced it myself. Peace of cake. Car needs new fuel pump and also repair of cat. converters and front axle and some electronics in dashbord.
Originally Posted by LaserRedG35VS
Got an update for the crew. I am now at 168000 miles. Thank god the car is still running like new. I do oil change ever 2500 miles. Changed the clutch once since I got it at 128000mi. I didnt burn it, I got a fresh oem clutch for 200 sum dollars so I just replaced the old one (which was soon to go). I was planning on doing a motor flush with Alcohol, good idea? Also, I dont think I ever replaced the differential fluid but I dont know if it needs to be changed or not? Any advice is well appreciated.
Old Jul 7, 2016 | 07:26 PM
  #1187
chefjeff's Avatar
After rebuilding my motor for oil consumption I would personally not think a flush is necessary. At 180,000 miles my motor was pretty clean thanks to the aluminum block and heads the coolant channels were almost spotless. Little oil build up but as long as the oil is replaced regular it is probably all good.
Old Jul 19, 2016 | 10:29 AM
  #1188
Senko's Avatar
Hello All, Figured I would chime in with my 05 G35x Sedan. 178k miles now. Bought it used with 111k
Old Jul 22, 2016 | 09:41 PM
  #1189
IllaNoizeTV's Avatar
Nice! What have you replaced in that time frame?
Old Jul 26, 2016 | 01:18 AM
  #1190
Neowind's Avatar
just bought a 05 G35 sedan with 107k
don't know should I change tranny fluid and spark plug ...
Old Jul 26, 2016 | 04:38 AM
  #1191
QX1's Avatar
QX1
Of course you should check the oil condition before to start change in tranny and in rear axle dfferential. engine oil you should chnge immediately.
Old Jul 26, 2016 | 08:46 AM
  #1192
Texasscout's Avatar
Start fresh.
Old Jul 27, 2016 | 12:48 AM
  #1193
JDLu's Avatar
Starting to worry a bit .. G35x is mainly "the wife's" car, and it's close to 120,000. Not much for 11 years -- it's a 2005 -- but fair amount of "town use". It HAS seen the Atlantic and the Pacific (we live in Nebraska). Just worked on the rear license plate -- bolts frozen up -- and the light above the license plate got bumped and FELL OUT. It was COMPLETELY rust/rotted! The car has always had Blizzaks in the winter .. we live in the hills -- and they salt the streets a bunch. 3.5 liter is starting to use a little oil -- maybe a qt every 3000 miles. first had to add between changes (full synthetic" at about 86k. JL
Old Jul 28, 2016 | 06:54 AM
  #1194
Texasscout's Avatar
Sounds like mine, except for the rust.
Old Jul 28, 2016 | 08:37 AM
  #1195
QX1's Avatar
QX1
Just recently changed oil in differential with Motul 75w85 90PA and it changed dramatically how car performs now and even economy. I did not expected such positive results. Litte bit rust in bottom of car after 2 years winters in salt mill. They use here very much salt in winter times.
Old Jul 28, 2016 | 09:37 AM
  #1196
gary c's Avatar
What I posted here isn't for high mileage cars!
SLICK is currently showing 63K miles on her clock. Something amazing happened a few days ago, after making a run to Ventura harbor her gas gauge was down to 1/4 and I needed WIX oil filters for both my cars. While at the Auto Parts store I bought Red Line injector cleaner which I added leaving the store even though it's supposed to be for a full tank. Driving to my Chevron station I noticed a difference in SLICK and her throttle response! Evidently Ca. gas had been clogging up her injectors will all their additive B.S.! This is like a tune up, quarter tank and add the whole bottle of Red Line and drive for a couple miles before filling up, results are very noticeable...Gary
Old Jul 31, 2016 | 12:38 PM
  #1197
03Sedan6MT's Avatar
Update
Originally Posted by 03sedan6mt
114,000.
128,000
Old Aug 2, 2016 | 02:58 PM
  #1198
99champ's Avatar
About to hit that 70k mark. Will get past there today. 04 coupe.
Old Aug 7, 2016 | 08:25 PM
  #1199
Blue Dream's Avatar
I drove ttrank's car solo
This is a sedan thread so GTFO, lol just kidding.
137K on my 05 sedan, just replaced a cracked radiator and thermostat. I've spent less than $500 on anything other than routine maintenance and the figure includes the rad, thermostat and both front lower control arms which I would consider wear and tear items anyway.
She burns oil like **** though, almost 2 quarts in 5k miles and it's a 5AT. Motor still runs strong as it always has, no loss of power according to my most recent dyno trip.
Old Aug 8, 2016 | 04:54 PM
  #1200
aghumra17's Avatar
60k on my 08 sedan
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
