Piece of Garbage expensive Catalytic Converters
Its been rattling for 20k miles now, and its not the damn heat shield, and now CEL is on, so want to replace.
04 has 110k on it, question is:
1) replace with oem cat - best price is $1000/ea?
2) replace with berk HFC's? - they told me $499 for the pair?
3) find use cat?
No mods, or anything, just need another 40k miles out of this car. Dont want to put a lot of money into it, but still want it to run right. Any suggestions, what difference would one be over any other.
3) find use cat?
I wouldn't buy used ones unless they had very few miles and you were getting a killer deal.
Looking at your options it looks like Berk would be the obvious choice.
$2,000 vs $500. If it is the honey comb that came apart inside the cat, you will probably see an increase in performance and fuel economy once you relplace them.
buy some test pipes second hand for $100, go to the nearest uprev protuner and get a tune, bam problem solved and your car will run amazing.
The rattle might be the heat shield cover/protector over the cats. I had a rattle because of the heat shields being all rusted up, cracked, and parts missing. Just have somebody remove the shields and the rattle should be gone. hopefully.
If it's the guts of the cat you will usually notice a difference in performance and or fuel economy because the honeycomb guts break loose and cause a blockage in the exhaust.
No. High Flow Cats are not CARB legal even though you may still pass sniffer tests with them on your car. In fact, they have been banned from being sold in California.
I believe federal law stipulates that used cats cannot be sold or installed. I ran into this problem when looking for a replacement in my old Acura ($1100 from the dealer)[this was in Florida btw which has no emission standards]. Just saying if one were to buy used cats they would probably have to install the cats themselves.
