Stillen vs Borla... on G35 Sedan/AT
Old Dec 8, 2004 | 05:58 AM
subrobo's Avatar
Just bought stillen cat back from grubbs infiniti
after a year...i finally called them up and place an order.
Ps. What it the free sat radio their offering? anything cool about that?
Old Dec 8, 2004 | 02:43 PM
BrianV's Avatar
Jimmy, it still has the bassy drone at the RPM's you specified; my bet is it'll be louder then your custom rig since the stock muffler is still so ultra-restrictive. I found it untolerably loud and my g/f wanted to kill me, so I invested some time and money and added a muffled magnaflow xpipe into the system, it helped significantly and only minimally drones now at that same RPM range.
Old Dec 8, 2004 | 03:46 PM
03rollaS's Avatar
Would either of these work for the X? Im thinking they wont due to different routing of exhaust(because of AWD)?
Old Dec 8, 2004 | 06:22 PM
Dan_1's Avatar
Hey BrianV,
You must have some seroiusly sensative ears, because its no where as loud as you describe. You do get some droning around 4000 rpms, but its not that bad, in fact if you turn on the radio ad med. volume you dont really even hear it.. When I first got mine on I was a little surprised at how much louder it was then the stock system, but grew to like it after awhile... plus it does quiet down some after you get a few thousand miles on it.
Here's my advice on aftermarket exhausts...
If you dont want increased noise, Its best to advoid aftermarket exhaust, as all exhaust that make additional HP are going to be louder then stock.
I know some exhausts (like the Nismo) sound pretty close to stock during cruising speeds and only sounds loud at Full Throttle. But there not going to make the HP the Stillen does... Actually even some people complain the Nismo is to lound, which to me is funny because it only sounds slight louder then stock during normal driving.. So people like this should not spend there money on an exhaust.
Hey Jimmy I would also recommend the Stillen Big Air Flow Intake & 350z tube... I have them on my setup and it seemed to quiet the sound of the exhaust a bit..
Old Dec 9, 2004 | 01:24 AM
GeeMan's Avatar
I'm with Coolie and I'm old. I luv the Stillen every time I start the G up. When you romp on the accelerator it is heaven. The kick in the pants after 3000 RPM is awesome.
Old Dec 11, 2004 | 03:06 AM
subrobo's Avatar
Just ordered stillen cat back, im still waiting for it. I'll try to make some sound clips for you guys when my exam finish.
Old Dec 12, 2004 | 01:00 PM
nismo4090's Avatar
Jimmy3005 can you type or spell?
Old Jan 15, 2005 | 10:42 PM
njsfastestg's Avatar
G SQUAD
where are the sound clips man?
Old Jan 16, 2005 | 09:24 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Cool Stillen......
I have an X so I can't do the Y-pipe as of yet....but was very happy w/the results I got w/ the Stillen "single " rear pipe ($317.00 through Stillen) and an 05' G35 mid-pipe (approx $200 plus gaskets from Infiniti) I saved monster weight and got great sound (just right and not too loud) with good performance gains....bcool...JBX
Attached Thumbnails Stillen vs Borla... on G35 Sedan/AT-dscf0015.jpg   Stillen vs Borla... on G35 Sedan/AT-dscf0001.jpg   Stillen vs Borla... on G35 Sedan/AT-dscf0005.jpg   Stillen vs Borla... on G35 Sedan/AT-dscf0001-2-.jpg
Old Jan 16, 2005 | 10:17 AM
Gsedan35's Avatar
I have driven a sedan with the Stillen TD. While I support the notion that it will be the leading contenter power wise. Anyone considering the exhaust would to well to request a ride and drive with someone close to you that has the exhaust on their sedan. I does increase cabin noise to a not so small degree, I compleatly understand why a few owners of the stillen TD sedan system complain about droaning. AT car's will be even more effected since the a/t tranny will conspire to keep the engine in the rpm zone most likely to cause the noise. Just to say it, it's also a good reason to check for a G35 gathering near you so you can ask for a ride and drive at that time.
The borla has also dyno'd well, but also suffer's from simular noise issues. The Fuji would be the best bet to avoid the noise issue, make certain that the Fuji y-pipe you'd pair it with has a 70mm output. If it's a 76.3mm output, by the Jic Y-pipe instead which is also 76.3mm, but is a better design IMO.
Old Jan 16, 2005 | 12:10 PM
I think I managed to save myself from the often complained about drone/noise by using the Coupe mid-pipe. Sounds very similar to a stock 05' coupe....just a hair throatier/louder.JBX
Old Jan 16, 2005 | 02:15 PM
  #30
Hyde's Avatar
Originally Posted by G35Lin
FUJI!!!!! way to gooooooo !! Nice power gains, not loud at all.. Great.... i got the tanabe Y pipe tho! Look sgood and supposedly has 1 extra hp over the Fuji Y pipe(according to Tanabe's website...)
Ed
yes, the only exhaust to go with....
Stillen and Borla just plan suck compare to Fujitsubo.... Stillen and borla exhaust should NOT even be fitted onto our cars.... it just downgrade the G35
