05 Sedan HID Headlight Issue
Okay guys, My Passenger headlight stopped working. I bought a new bulb ($100.00, never buying a car with HIDs again!) and after installing the new bulb, still no pass side headlight. My fogs work along with everything else. How do I check to see if the ballast is bad, or if its wiring? It just stopped out of no where 1 day. Car is an 05 with only 57k on it. Its no longer under waranty. Thanks for the help in advance, and if anyone knows if there is a DIY to changing the ballast or what ever is wrong. Thank!
Sounds like a ballast. An don't give up on HID, they're vastly superior to regular setups. I bought a set of 6000K bulbs a little over a year ago for $30 from someone in the Marketplace. One has been a little flaky lately so I bought another set for $20 and they look fine. $100 is retail store pricing.
HID kit, 2 ballasts, 2 bulbs here for 1/3rd what you paid for a bulb.:
http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
I have fogs from DDM tuning, but BuckEye is correct, the headlights are 35w not 55w. Im checking the fuse tonight....Does anyone know where the fuse is? I hope Im lucky that its just the fuse and not the ballast. Where can I get a ballast besides the stealership if its not the fuse? Thanks for the replies
I bought the car from a private seller and I think he said the warranty was up at the time. Il call the dealership tomorrow and see if its still under warranty.
I checked the fuse, and Just my luck, it is not blown. Therefore it has to be the ballast.
Ill try swapping the ballast and see if that works...but I dont wanna have to go thru the "checking fuses stage" if switching them could blow the fuse.
You are reading
Raptor 55 Watt Kits Mail Order Only
The kit is either 35 or 55 watt. The price you see is for 35W
Dont ask me how it happened, but I disconnected the battery to get to the fuse box and all the fuses were good. put the battery back in, reconnected and Shazam! the pass side headlight works.....Weird, I guess it reset all the computers and the ballast?? lol i duno, but if it happened once, im sure with my luck it will happen again.
thanks Buckeye, def checking into that!!
bTanz
Oct 15, 2015 02:31 PM
