get it, and buy the infiniti extended warranty, and then report oil consumption and you got yourself a new engine
Quote:
^This. I wouldn't touch that car with a 10-foot pole.Originally Posted by Jeff92se
You should feel lucky you caught it vs the dealer topping off the oil level and not saying anything about it.
Quote:
Mine uses oil at just about the same rate.
When I first bought my car, before signing anything I checked the oil, but couldn't really tell what was going on due to the fact I didn't know about the retarded design of the VQ dipstick and the fact you have to wait about 30+ mins after you shut the car off before you can get an accurate read
Anyway, I changed the oil a few days later and only got about 2.5 QT out, which worried me a bit. However, I did change it on an incline (found out later the G don't like that)
But the car did fine, and I checked it regularly, noting that it did use oil at a higher rate than I was used to from previous cars.
However, I switched to 10-40 and a better oil and it's rate of consumption went down.
That was all at around 100K and I'm over 130k now with no problems.
One thing to note though, I did have a valve cover off not long ago and there was no sign of sludge. Cams looked practically brand new. So yeah... the sludge thing would concern me too.
How much are they asking for it?
What they can sell it for is 11kOriginally Posted by NFSP G35
^+1Mine uses oil at just about the same rate.
NFSP G35
? = 2B || !2B
close
- Join DateApr 2009
- LocationTallahassee, FL (or thereabout)
iTrader Positive Feedback100
iTrader Feedback Score(22)
Liked:852 Times in 640 Posts
That's too high, unless it has low mileage... but then again, that's kinda negated by the whole sludge issue.
Quote:
It said it had 95,600 miles on the add, but found out it actually had 99,620 after looking at the service records. So by no means was this low mileageOriginally Posted by NFSP G35
Wannabe6MT
-MN G Crew-
close
- Join DateMay 2007
- LocationFargo ND/Eden Prairie MN
iTrader Feedback Score(10)
Liked:205 Times in 157 Posts
Granted, it was an 04 6MT with Nav.
Ashley, have you shopped G35s lately?? The prices have skyrocketed.
Quote:
what would you have thought it would have been worth? Prices did sky-rocket, sadly it might be smarter to wait until winter or something at this point.Originally Posted by NFSP G35
yeah.. way too much NFSP G35
? = 2B || !2B
close
- Join DateApr 2009
I wasn't aware the prices had gone up. Still, 11 Gs is to much to pay for a car that may end up being trouble
Quote:
Oh definitely too much for that car considering the circumstances now. I have moved on from that car and am continuing my search. Originally Posted by NFSP G35
I was just curious as to what you thought it would be worth if it didn't have the oil/ sludge issue.
The prices of these cars seemed to be cramming right into each other. It seems you can find an 03/04 with 100k on it for 10-12 or an 05/06 with 70-90k for 12-14, 50-70k for 14-16 and then you jump right into 07+ with 100k starting at as low as 17's
Wannabe6MT
-MN G Crew-
close
- Join DateMay 2007
They kinda just bottleneck onto each other.
Quote:
Yeah tell me about it....CrazyOriginally Posted by Wannabe6MT
- FS: 2006 6MT DG Coupe - 84k Miles
- FS: 06-07 G35 Coupe Tail Lights
- FS[SoCal]: Barrel of a Ronal Rim
- FS: Motordyne TDX2
