Quick Question - would a 19x9.5 +25 fit in the rear
Old Jul 17, 2011 | 09:05 PM
tran2000's Avatar
I'm looking to buy some rims but would a 19x9.5 with +25 offset fit in the rear without heavy modification? i had my fenders slightly rolled but i'm currently on stock suspension right now. i'm not looking to run negative camber or anything, just want to see if it fits without poking out too much.
Ohh and the tire size is 255/35/19 if that matters
Old Jul 17, 2011 | 09:08 PM
CandlestickPark's Avatar
ill Sedan
At stock ride height it will stick out too much, you'll need to roll your fenders flat, drop it and dial in some negative camber (a bit more than -2 probably).
Old Jul 17, 2011 | 09:12 PM
tran2000's Avatar
thanks man, i figured they would especially at stock height.
Old Jul 17, 2011 | 09:31 PM
Blue Dream's Avatar
I drove ttrank's car solo
Yep Marcus is right. And you'd probably want to downsize the rear tires. A 255 on an 9.5 +25 would require more than -2 camber to fit.
My specs and I poke a minute amount past the fender, really looks perfectly flush from most angles. I also can't dial in more positive camber, I have about a 2 credit card thickness between tire sidewall and fender.
19X9.5
+33
245/40/19
-1.9 camber
Old Jul 17, 2011 | 10:04 PM
chink-ah-saur's Avatar
If you lower it and,run 245/40/19 natural camber will come in and youll be good
Old Jul 18, 2011 | 12:11 AM
Nvm ..im runing +30
Old Jul 18, 2011 | 02:00 PM
4DGS's Avatar
Blue, I thought you were more aggressive for some reason.
Old Jul 18, 2011 | 02:17 PM
Blue Dream's Avatar
Nah, I'm just where I want to be.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
