2006 G35x Sedan - Where to find Sat connector?
Old Jul 29, 2011 | 07:16 PM
mawsoccer's Avatar
I'm looking to install an AUX jack. It looks like the PA15-INFI is the easiest to install if I have the right adapter in the trunk area?
Is that correct? If so, where would I look for that connector in the trunk?
Thanks in advance!
Old Jul 29, 2011 | 10:51 PM
Mustang5L5's Avatar
It's not behind the rear panel against the seat like the 03-05 models
On the 06, it's on the passenger side of the trunk, under the rear deck. So if you pull down the trim liner from under the rear deck, on the right side you should see a connector not plugged in.
Old Jul 30, 2011 | 01:19 AM
mawsoccer's Avatar
Hopefully I won't screw up the interior of the trunk trying to get to it. Is there any trick to not permanently ruining things?
Old Jul 30, 2011 | 09:24 AM
Mustang5L5's Avatar
No trick...that hard to do
nickmcc123
Lights
Oct 7, 2017 12:18 AM
atk08
Jul 30, 2015 03:12 PM
nickmcc123
Jul 29, 2015 05:14 PM
ResoG35Sedan
Jul 14, 2015 10:30 AM
