Lowering my car
Old Jul 29, 2011 | 09:09 PM
ronniepetras's Avatar
Lowering my car
I'm getting BC coil overs hopefully by this week, anything else I need to change or add to while I'm at it..
As far as I know my bushings need to be changed
Old Jul 29, 2011 | 09:25 PM
gannicus's Avatar
Camber kit ust the rear
Old Jul 30, 2011 | 12:12 AM
Rajen's Avatar
^ +1 Depending how much you are lowering you will need:
1. Rear Camber Arm
2. Rear Toe Bolt (if your rear springs are ON the strut and no longer in the rear spring bucket then you can get a rear toe link if you want to remove the bucket and save weight).
3. Front Upper Camber Arm
Get at least the rear camber arm.
Old Jul 30, 2011 | 09:10 AM
pghg35sedan's Avatar
Im lowered on BC Coilovers I just used rear camber arms.
Old Jul 30, 2011 | 12:38 PM
SkyWay's Avatar
You need both camber arms and toe bolts in rear. When you change toe or camber, the other one changes with it.
Besides toe is what eats your tires prematurely, a lot more than negative camber.
rezendvous420
May 31, 2020 01:26 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
itschuckster
Jul 25, 2015 08:07 AM
Kal Hamm
Jul 24, 2015 08:55 AM
Karnicle
Jul 23, 2015 05:08 AM
