(!) popping up on dash
Old Aug 6, 2011 | 03:44 PM
Carrottop401's Avatar
in the owners manual it says low tire pressure so i filled my tires up to 44 psi which is the max it says i shuld have on the tires.... the (!) is still popping up so wat do i do?
Old Aug 6, 2011 | 03:46 PM
alfhasg35's Avatar
may possibly need to reset the tpms sensors at the dealer...
Old Aug 6, 2011 | 03:56 PM
G35SedanGrn's Avatar
44PSI is a lot....most I do is 35psi....maybe you over inflated & that's why it's goin off? Try 35PSI & drive around for a bit & see if it goes off if not them take it to the dealership to get reset.
Old Aug 6, 2011 | 04:01 PM
TIAN's Avatar
Hold The Line
^ I agree. 44psi is too much. 35psi is just right.
Tpms might have gone out is another possibility.
Old Aug 6, 2011 | 05:41 PM
hL.'s Avatar
hL.
It says 30 PSI on the sticker in the door jams
Old Aug 6, 2011 | 06:37 PM
socialconflicts's Avatar
LOL!!! u filled the tire to its cap? funny.
i smell some fresh meat
Old Aug 6, 2011 | 06:39 PM
04G35NYC's Avatar
32 Psi is perfect.
Old Aug 6, 2011 | 07:07 PM
GeeWillikers's Avatar
Walking The Fine Line...
Prolly a TPMS issue rather than a true pressure issue.
Old Aug 6, 2011 | 07:31 PM
4D05G35's Avatar
+1
Does the light come on right away or after driving a bit? Mine comes on after about 50 miles, but thats because I dont have the sensors anymore.
Old Aug 6, 2011 | 08:46 PM
5150DS's Avatar
Do you have a full size spare? If so, did you check the pressure in it?
Old Aug 6, 2011 | 09:03 PM
alll my tires were around 35 psi and the (!) was still on, so i filled them up to about 40 because all of my tires say 44 psi and the light still stayed on...
Old Aug 6, 2011 | 10:12 PM
4D05G35's Avatar
Thats the MAX pressure not the normal operational pressure. Check your door jam for the proper air pressure (cold). For example my door jam says 30psi for my sedan, but the tires say a MAX of 50psi.
Set your tires to what your door jam says when they are cold. Does the light come on instantly or does it come on after driving a while? Does the light go off after a little driving (if it come on instantly). Do you have stock wheels with the original TPMS or have you changed them out?
Old Aug 6, 2011 | 10:37 PM
NightShift's Avatar
If the light blinks it indicates a problem with a sensor or within the system, if it is simply on it dictates that the system is not satisfied with one or more of the pressures. As the others have stated fill your tires to what the door jam says not what the tire says. The max pressure on the tires is what you can inflate to without risk of rupture. Also the light isn't going to turn off instantly, you'll need to drive a few miles first. 32-35psi is the most common and safest pressure.
Old Aug 7, 2011 | 12:41 AM
bigc's Avatar
Wings Nation
Per the FSM, if the light comes on with an audible alarm, it indicates tire pressure is low. If the light comes on with NO audible alarm, its most likely a problem with the TPMS itself (communication error between the senders and the receiver, bad sensor, etc).
Old Aug 7, 2011 | 12:50 AM
pricojorge's Avatar
you have to drive around (1-2~ miles) for them to turn off (unless sensors' broken)
