Z-tube install
Aug 13, 2011 | 05:12 PM
Hey any fellow local Boston members wanna give me a hand to install a z-tube? My mechanic cant do it! I dont have the time to do it myself, kids and career take up most of my time!
Reply 0
Aug 13, 2011 | 05:19 PM
I'd help ya out but I'm on the west coast.
It's really easy to do.
All you need is a screwdriver, 10mm socket wrench, pliers and 15 minutes.
http://www.6mt.net/mod-g35-350z-intake.php
Reply 0
Aug 13, 2011 | 05:21 PM
Quote: Hey any fellow local Boston members wanna give me a hand to install a z-tube? My mechanic cant do it! I dont have the time to do it myself, kids and career take up most of my time!
^ A Z-tube install should be very simple - although I didn't do my own.
Probably better if you posted up in your regional subforums than this one for local help. If you're near Rhode Island I bet Naughty240 could help you. And then some from what I hear
Reply 0
Aug 13, 2011 | 05:47 PM
Find a different mechanic ASAP!, if he cant unscrew 3 bolts,(7 with the cover on),(4 on cover) + (2) 10mm and (1) flat head, and then get some pliers to undo the vacuum hose. Then why is he a mechanic?
Reply 0
Aug 14, 2011 | 01:47 AM
Agreed. Truly easy install. 15-20 mins MAX!!!
Reply 0
Aug 14, 2011 | 04:17 AM
rhode island is far no? and its easy as can be i dont have one but i did one for my boy i personally dunno if there worth it i read the thread were a fellow member tested all different intakes on the dyno and wasmore impressed with the stock setup
Reply 0
Aug 14, 2011 | 09:57 AM
Quote: Find a different mechanic ASAP!, if he cant unscrew 3 bolts,(7 with the cover on),(4 on cover) + (2) 10mm and (1) flat head, and then get some pliers to undo the vacuum hose. Then why is he a mechanic?
Exactly what I was thinking.
Reply 0
Aug 14, 2011 | 10:21 AM
The Z tube is the stock setup. The difference between the G and Z intake tube is the G has baffles and chambers built along it to silence incoming air. The Z tube is just a straight tube. It has a slightly more aggressive growl when under throttle due to not having the baffles. stock tube period showed best results as compared to most aftermarket intake tube setups from all I've read.
Reply 0
Aug 14, 2011 | 08:46 PM
so to change to a Z tube on my 03 G35 is just go take the intake tube off of a 03 350z and bolt it on my G35?
Reply 0
Aug 14, 2011 | 08:57 PM
^ Yes
Reply 0
Aug 14, 2011 | 10:44 PM
If you can change a wheel you can install a Z-tube. Hell it would take longer to jack up the car and remove the lug nuts than it does to replace the intake tube.
Reply 0
Aug 15, 2011 | 08:38 AM
I'm in Boston, but my schedule is probably tighter than yours.
But seriously, it's rediculously easy. Just two band clamps really.
Reply 0
Aug 16, 2011 | 09:44 AM
My G35 is a 2003 so what years of a 350Z will the tube interchange? ready to hit the salvage yards to get one thx GRT
Reply 0
Aug 16, 2011 | 10:13 AM
send me a PM, I can do it as long as you can come to me.
Reply 0
Aug 16, 2011 | 11:04 AM
Thanks guys and thank for the DIY link good to know!
Reply 0
