Bird Chirping Noise coming from Rear Passenger side Wheel on a 03 G35 Sedan
Old Aug 15, 2011 | 10:10 AM
pjgangster's Avatar
Hey guys, need some help identifying this noise from my rear passenger wheel.
It's high pitched and embarrassing. The noise comes and goes. I can hear it when I turn left also. Speeds between 20-40mph I can hear it the most. When the brakes are pressed it goes away, or over speeds of 45. It's not a grinding, like a bird chirping constant. Constant chirping sound high to mid pitched sound. It will keep chirping until either I brake or speed up.
I am pretty confused as to what this is. I replaced the front and rear rotors & pads about 3 months ago. Duralast gold cmax brake pads and new rotors off ebay, I believe some brakelabs.
03 sedan has about 130K on it. Thanks,
Old Aug 15, 2011 | 10:13 AM
Mustang5L5's Avatar
Pull the wheel off, disassemble the caliper and relube. Lube the slide pins with high temp grease and apply brake caliper lube to the contact points of the pad to the support bracket and the caliper itself.
That should take care of the noise.
Old Aug 15, 2011 | 10:42 AM
jimNC's Avatar
I re-lubed my rear caliper bolts not long ago (03 Sedan) and I could not slide out the bolts that were more toward the front of the car because of clearance issues. I just pulled it out best I could and weasled some grease on the pin, hoping it would kinda move around in there over time and spread out.
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
teamghost
Jul 28, 2015 04:52 PM
wylin
Lights
Jul 18, 2015 06:12 PM
