Dual Exhaust on Sedan
Jan 29, 2012 | 05:17 AM
I am thinking
1x HR Y-Pipe
1x Magnaflow 12158
2x Magnaflow 12866 (Maybe)
Reply 0
Jan 29, 2012 | 10:50 AM
That would work fine as long as you keep the stock cats. If you get HFC or test pipes, the Y-pipe should be changed for something else.
Reply 0
Jan 29, 2012 | 11:10 AM
Quote: That would work fine as long as you keep the stock cats. If you get HFC or test pipes, the Y-pipe should be changed for something else.
Maybe I should make the center muffler a 3" in/2.5" out so I can use ART + XYZ w/HFC.
Reply 0
Jan 29, 2012 | 11:50 AM
Why not just keep it 3" outlet at that point? There's no drawback to it that far back in the exhaust.
Reply 0
Jan 29, 2012 | 11:59 AM
Quote: Why not just keep it 3" outlet at that point? There's no drawback to it that far back in the exhaust.
Since I'm not on FI, it would give better peak power, but my low + mid would really take a dive in power which is why I want to bring it back down to dual 2.5. I am currently PM Tony to see if he would chime in on the subject, I would prefer to keep my HR Y so I don't have to go to 3"
Reply 0
Jan 29, 2012 | 12:13 PM
That's a common misconception. You only want it 2.5" before the merge. After that, you want the diameter as large as possible. That's why the TDX2 is designed to go from 2.5" to 3".
Reply 0
Jan 29, 2012 | 12:26 PM
The dual 2.5" should be more than enough room to compensate for the single 3" advertised for the sedan, I'm not trying to create backpressure. Like I said I'm waiting on a reply from Motordyne since the nova is similar to the system I came up with.
Reply 0
Jan 30, 2012 | 09:44 AM
See this link for background on testing I did.
http://my350z.com/forum/intake-exhau...k-for-n-a.html
As for fitting a Coupe dual exhaust in the Sedan, I dont really know what it will take. I havn't tried it myself except for the single exhaust.
To do a dual exhaust on the Sedan it will take quite a bit of custom work.
Reply 0
Jan 30, 2012 | 10:03 AM
This may help: https://g35driver.com/forums/intake-...-complete.html
Reply 0
Jan 30, 2012 | 10:53 AM
I would eventually switch to ART-Pipes and the XYZ w/HFC module, but I can keep my stock Cats and HR Y-Pipe for now, switch my Mid-Pipe to a 3" and the split it into 2.5" duals. Keep this diameter until the right before the Axle-Back pipes, here I would need diffusers to increase the diameter back up to 3" before the gases enter the final mufflers (See below pictures). Am I understanding this correctly Tony? Should I do dual 2.5" into 3" diffusers or dual 3" into 3.5" diffusers?
Reply 0
Jan 30, 2012 | 10:54 AM
Tony's post on my350z:
Quote: Back pressure (at least on our engine) is NEVER a good thing for NA applications.
It is a widely spread myth that some back pressure is good, but it is 100% FALSE.
There clearly are situations where smaller diameter pipes can outperform larger diameter pipes but this is not because of back pressure. This is because of scavenging. And when tuned properly, scavenging actually reduces back pressure as seen by the engine.
But be careful in the assumption that smaller automatically equals better performance. It is highly dependent on where the smaller diameter pipes are being used.
Small pipes near the engine can be good for scavenging and power, but as the pipes move farther and farther away from the engine the effect of scavenging rapidly diminishes. If scavenging cannot be taken advantage of, then small/restrictive pipes must be completely avoided.
Back pressure can only reduce power. Do not confuse this with scavenging.
Scavenging actually reduces back pressure on a tuned cyclical basis.
With each pulse released during the exhaust stroke of the engine, the pulse travels like a shotgun blast down the exhaust pipes. The high intensity blast creates a shockwave with a large positive pressure at the wave front. This wave front is traveling so fast that even when the piston reaches TDC and all the gas is expelled by the piston, the fast moving slug of exhaust gas doesn't stop and it rarefies the gas and creates a vacuum behind the shockwave.
It is the vacuum behind the shockwave that sucks out any remaining exhaust gas from the cylinder. This vacuum also pulls more fuel/air mixture through the intake valves during the intake/exhaust valve overlap period. And this is how more power is made. This is the scavenging effect. It vacuums exhaust gas out of your engine!:thumbup:
Adding back pressure can only kill off this vacuum that you want.
NOW HERE IS HOW THE MYTH STARTED.
IT WAS A MISINTERPRETATION OF TEST RESULTS.
Sombody a long time ago probably did the same series of dyno tests I did on varying pipe diameters. Like I did, they probably found that smaller diameter pipes can yeild higher HP and TQ. They probably mistook this for back pressure and put it out in the public. Smaller diameter pipes can provide higher performance when used properly. But small diameter pipes are only desirable when they are very close to the engine.
For example:
I did a series of dyno tests on various diameter test pipes ranging from 2.5", 2.25" and 2.0".
Before conducting the tests, my initial guess was that the larger diameter pipes would produce the highest HP with lowest TQ. And the smaller diameter pipes would produce the lowest HP and the highest TQ.
Well... I was 1/2 right...
As expected, the dyno testing showed the 2.5" diameter test pipes made the lowest TQ. And as expected, the dyno testing showed the 2.0" diameter test pipes made the highest TQ.
But here's the kicker. The 2.0" test pipes made 2 more HP than the 2.5" test pipes! ...It left me thinking "COOL.:thumbup: Smaller diameter test pipes make more TQ and more HP. That's a wining combination!"
So sombody a long time ago probably misinterpreted the smaller diameter as adding performance by being more restrictive. But this is not the case. It is because of increased scavenging. Smaller diameter pipes near the engine increase the velocity of the shockwave and thereby increasing the effect of scavenging. It was a misinterpretation of the results.
So I continued down this line of testing at the Y-pipe primaries. Using the 2.0" test pipes, I then tested various Y-pipe primary diameters. 2.0", 2.25" and 2.5".
The expectation was to see similar results... but not quite this time. At least not at the Y-pipe.
The 2.0" Y-pipe primaries did indeed provide the highest TQ, but it brought a good portion of the HP down. 2.25" primaries were better but could still be improved upon. The 2.5" Y-pipe primaries provided the best peak power and the best average power.
So dyno testing proved the best test pipe diameter is 2.0" diameter and the best Y-pipe primary diameter is 2.5".
I then continued further down this line of testing on the mid-pipe and made some more interesting observations. Testing mid-pipe diameters at 2.5", 3.0" and then a fully open Y-pipe.
What I did find was that there was no scavenging effect possible after the Y-pipe. There was nothing to gain from the smaller diameter what so ever. In fact, the only thing that had any effect was simple back pressure.
Using a open Y-pipe as the baseline I found that connecting a 3" single exhaust had no effect on TQ and with only a small 1.5 HP decrease.
The 2.5" midpipe slightly reduced TQ and was ~2.5HP down from than the 3" midpipe.
This series of tests established:
1) There was no scavenging possible after the Y-pipe.
2) A smaller diameter midpipe can only decrease HP&TQ
3) There will be rapidly diminishing returns beyond a 3" midpipe
4) With power to weight ratios taken into consideration a 3" midpipe can be considered optimum. 3" also allows more headroom for medium boost FI applications.
Going from 3" to a 3.5" midpipe may at best provide a 0.5HP increase. So from a weight point of view, going larger than 3.0" would be counter productive for NA applications.
I then conducted another series of tests at the end of the Y-pipe.
1) Attaching a 3" diameter butterfly valve with variable position restriction plate.
2) Attaching a 6" diameter parabolic diffuser to reduces pressure drop below that of a 3" open pipe.
The purpose of the butterfly valve restriction plate was to directly test the effect of raw back pressure on performance. And the results were very clear.
BACK PRESSURE RAPIDLY REDUCES PERFORMANCE.
I dyno tested the valve at various levels of flow restriction. From wide open to almost fully closed as back pressure was increased, performance rapidly decreased.
This set of dyno plots is proof positive that back pressure is the enemy of power and torque.
Let the myth of back pressure be permanently dispelled from the vocabulary of this forum!
After that series of tests I started another set of tests that decreased exhaust pressure beyond that of a simple open ended 3" pipe.
A 6" diameter parabolic diffuser was clamped onto the end of the Y-pipe. This was used to decrease flow resistance below that of a open pipe.
Dyno tests of the diffuser showed an instant 4-6HP increase over that of a open Y-pipe!:thumbup:
This picture below is a picture of a 5" linear diffuser. It doesn't perform quite as good as the 6" parabolic diffuser but the 6" diffuser is completely impractical for fitment and production reasons.
6" is too big for fitment under the Z and the parabolic shape also gives it a curvature that makes the production process MUCH more difficult.
This is the diffuser used on the MD ShockWave single exhaust system. It can also be attached directly to the Y-pipe for drag race applications.
So while there are rapidly diminishing returns with going to larger and larger diameter tubing after the Y-pipe, significant gains can still be made by use of diffusers.
The back to back dyno testing shown below was a simple open Y-pipe as the baseline and then with the diffuser attached.
Reply 0
Jan 30, 2012 | 10:56 AM
Here's Tony's post on diffusers:
Quote: To get an idea of how a diffuser works you need to consider all the kinetic energy being pumped out of the exhaust tail pipe.
For a normal exhaust system that uses 3" tubing conected to a muffler with a normal 3" outlet with a rapid expansion to a 4" or 5" tip, all the exhaust flow energy is wasted by shooting out all that exhaust gas at high velocity into the atmosphere.
If you have ever stood ~20 feet behind a car on the dyno you will see and feel the effects of all that energy being wasted. Standing behind a car on the dyno is like getting blasted by wind on a hot smoggy day.
It takes energy to move all that hot wind with such force. And all that wind is being blasted out of a 3" tube! So what is comming out of the tail pipe is quite intense. And its all just wasted energy.
But if you were to connect a 5" diffuser to a 3" tube the exhaust gas velocity will be slowed down and reduced by a fator of almost 3X.
And pressure drop is determined by rhoV^2/2g. In this case, rho and 2g remain constant and V^2 is the important variable.
Not only a diffuser brings the velocity down by a factor of nearly 3X. The total pressure recovery is determined by the square of the velocity. So the diffuser is recovering kinetic energy by converting Dynamic pressure into Static pressure.
So not only this means your engine doesn't have to waste energy by pumping out the exhaust gas so forcefully, it also makes it easier for a new fuel/air charge to get into the engine by means of scavenging.
Diffusers are commonly used in jet engines and rocket engines. They convert fluid movement into pressure. Or Dynamic pressure into Static pressure and vice/versa.
In the case of a I.C. engine we only want to efficiently convert dynamic pressure into static pressure. The way to do that is with a diffuser. For a diffuser to be efficient, it must be designed with the proper expansion ratio and diffusion angle. Like the cone shown above.
If you were to take a 5" exhaust tip and just bolt it onto a 3" pipe, it won't work. A regular exhaust tip has what is called a sudden expansion. It is unable to efficiently convert the kinetic energy into static pressure. It just dumps it into the atmosphere and wastes the fluid energy. But the diffuser organizes the flow in an orderly manner and gradually slows it down (efficiently) and all that kinetic energy is conserved.
The engine is still pumping out a lot of exhaust gas but a diffuser makes it a lot easier to do.
Reply 0
